Old 04-21-2006, 05:07 PM   #1
1979 31' Excella 500
Detroit Area , Michigan
Images: 43
Exterior refer door madness! Help!
Well I finally got the right door for my missing refer door for the exterior of my 79 31' International. It's the right fit but I seem to be missing some parts, what parts, I don't know. The way it is right now it will not fasten securely in the hole. Obviously it is missing some sort of knob that goes in the bottom hole but it seems to be missing weather stripping as well. Right now this would be a haven for mice yellow jackets etc.
Here are the pictures of my existing opening, along with the new door sitting in there:
top:
bottom:
right:
left:
and finally the door in the hole:
Anybody with an Airstream with the same door that can help me with some pictures on how this is supposed to look please post them.
wacnstac is offline   Reply With Quote
Old 04-21-2006, 05:19 PM   #2
Round on both ends
SafeHarbor's Avatar
1975 28' Argosy 28
Rutledge , Georgia
Hi, Wacnstac,
Well, you're missing the quarter-turn lock assembly on the bottom of it. These are not rare, and your local locksmith or maybe even hardware store can supply it. You should see the slot below where the little arm goes into.
Hey, you found a good looking door!
The rubber gasket is not elaborate, either. You can find several of them at Aircraft Spruce and Specialty on the net, but your local Autozone, etc, may have something similar enough on spools.
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 04-21-2006, 05:43 PM   #3
Images: 43
Can you take some close up pictures for me on exactly where your rubber gasket is on your unit?
Old 04-21-2006, 07:06 PM   #4
lewster's Avatar
Naples, FL , Hood River, OR
Any gasket that will either slip on the door or the frame will work, as their only function is to stop the door from rattleing. The door is a vent and should not need any type of weather seal on it. You might also want to put some aluminum screening over the inside of the vent openings to keep the mud dauber wasps out of the compartment. They do love to build nests in enclosed spaces like this
Old 04-21-2006, 08:34 PM   #5
Images: 43
Pictures please of original weather strip much appreciated!
Old 04-22-2006, 08:08 AM   #6
Images: 43
So does the weather strip attach to the door? On the inside? Around the outside? Seems like a nice mouse nesting area to me.
Old 04-22-2006, 03:08 PM   #7
Images: 43
A picture would be worth a thousand words right now.
Old 05-11-2006, 12:58 PM   #8
RBolton's Avatar
Belington , West Virginia
I started out to take a picture of my Argosy door that is similar to yours, no vents and painted but similar - but its pooring the rain down here. I'll get a pic for you later.My door has a key lock in the hole at the bottom and a seal on the door that goes all the way around.
RBolton is offline   Reply With Quote
Old 05-11-2006, 02:50 PM   #9
RBolton's Avatar
Here are pictures of my door. It is not vented but the hole looks more or less like yours. I hope this helps.Roger
ID:	21253   Click image for larger version
Old 05-11-2006, 04:43 PM   #10
enduroryda's Avatar
1994 21' Sovereign
Down on the corner... , CT
Mine is very similar to yours...I'll get you some pics.
If you can see in the pic there really isn't a gasket...it's a little strip of foam that attaches on the left and right inside of the unit. Hope this helps!
ID:	21259   Click image for larger version
enduroryda is offline   Reply With Quote
