Old 03-22-2012, 06:38 PM   #1
1985 25' Sovereign
KRUM , Texas
exterior door removal
ok , another question. to take the exterior door off by punching the hinge pin is this difficult? it looks to me like it could only be driven out from the bottom,it looks like a step pin but i have never had one of these apart any insite would be helpful. thanks a bunch for any help you can give...............dusty
dusty b is offline   Reply With Quote
Old 03-22-2012, 07:04 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Having tried to remove the pins I suggest you consider this approach.
Cut small holes through the interior skin to reach the nuts that hols the door on the trailer. This will allow you to remove the door and has some additional advantages. I got locked out of the trailer when the latch broke off in the closed position. When in through a window and removed the door by unbolting it.
When done you can cover the holes with blank 2x4 white electric box covers. Almost goes unnoticed.
I used the same idea when the dead bolt spring broke and I had to get to the door handle to get to the dead bolt.
2004 Excursion 4x4
door handle susans69 All Argosy Trailers 26 05-30-2017 10:23 PM
New W/H - Old Door musicmaster Water Heaters, Filters & Pumps 5 06-10-2012 10:02 PM
What size door? Skywriter 1966 - 1968 Safari 4 04-30-2012 03:41 PM
Exterior strip coming off - suggestions for adhesive? loislane General Repair Forum 8 03-21-2012 07:31 PM
Bathroom door vibrates open while on the road - need ideas lubelg Doors & Locks 0 03-18-2012 11:44 AM
