Old 03-01-2011, 04:23 PM   #1
1967 26' Overlander
Flagstaff , Arizona
Exterior Door Problem
My parents have an Airstream Overlander (circa late 60s, early 70s). The exterior door handle (a lever-type handle) came off, and it looks like the circular part may be stripped, so I'm not sure even getting a new handle is going to fix the problem. We can't figure out the best way to proceed, and obviously want to minimize creating any more damage.
Advice???
Thanks!
Debby
dreamweavers is offline   Reply With Quote
Old 03-01-2011, 05:18 PM   #2
kevin242's Avatar
1977 25' Tradewind
Waskesiu Lake , Saskatchewan
Hi Debby,
I suggest taking a digital picture of your handle and problem and posting them here along with the serial number of your trailer to help us positively identify the year.
You could also email the pictures and serial number to www.inlandrv.com , www.outofdoorsmart.com , or www.vintagetrailersupply.com to see if they can provide parts and advice on how to fix it.
Kevin
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
kevin242 is offline   Reply With Quote
Old 03-01-2011, 05:40 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Handle?
Can you post a photo? Which is the handle you have?
Name:	Bargman L66 Lock3.jpg
Old 03-01-2011, 09:39 PM   #4
1967 26' Overlander
Flagstaff , Arizona
Thanks so much! It is either the top one or the one on the right. I will take a picture (of what is left!!) tomorrow and post it. Thanks to you both!
Old 03-01-2011, 10:05 PM   #5
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
It's unlikely to be the one on the top or right as that model (L66) was never used on Airstream's. A similar handle (L77) was used on Airstreams in 59 & 60. Mid to late 60's trailers used the L100 or L200 which i believe is still available through Vintage Trailer Supply. 1970 & up for quite a few years used the "KT" lock, however it is obsolete & commands high prices on ebay.Colin
Colin H is offline   Reply With Quote
Old 03-02-2011, 02:04 PM   #6
1967 26' Overlander
Flagstaff , Arizona
Posting the Photos
Thanks to all for your attempts to help--much appreciated.
Here is a little more information: It is a 1968 Overlander.
I am attaching photos of the handle (which came off) and the remaining opening (that I think is stripped).
I appreciate your advice!
Debby
ID:	123461   Click image for larger version
Old 03-02-2011, 02:37 PM   #7
Debby
Debby.
That lock was used starting with the 1969 models, but someone could have installed it on your Airstream.
That lock is call a Bargman L-100 SPECIAL.
The "special" means it has been modified with a longer striker bolt, because of the thick cast entrance door frame.
Old 03-04-2011, 09:26 PM   #8
1967 26' Overlander
Flagstaff , Arizona
Thanks Andy and others! Here is my next question: How do I get what is on there off in order to be able to install a new lock?? Right now we can't get into the trailer or get the current configuration off??
Thanks again!
Debby
Old 03-04-2011, 10:18 PM   #9
Thanks again!
Debby
Debby.
Send a "little" kid, into the trailer thru an access door.
The lock is held in place with a couple of screws that can be removed from the inside, once the door is opened.
Old 03-04-2011, 11:11 PM   #10
1967 26' Overlander
Flagstaff , Arizona
WOW, not sure we can locate a "little" kid or even a "little" adult! Are there any other options??
Old 03-05-2011, 02:59 AM   #11
Smashing a window, is the other option.
Old 03-05-2011, 07:02 AM   #12
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Have you tried leaning against the door to take the tension off the latch, and turning the remaining piece with a pair of needle nose pliers?
When our door lock stranded us outside, I was able to get the window next to the door open, push out the screen, and hook the inside latch with a stiff piece of wire. I opened the door by pulling up on the wire.
Old 05-18-2011, 11:53 AM   #13
1972 27' Overlander
HERRIMAN , Utah
Door lock problems
I have a 1972 27' Overlander that we cannot get the entry door open. We put key in cylinder and turn it, lift handle and latch does not release. Had a locksmith out and he suggested drilling lock mechanism out or trying to pry door far enough out(there is quite a bit of play) to slide something in and release latch. Any help or ideas will be appreciated.
Hogger13
hogger13 is offline   Reply With Quote
Old 05-18-2011, 01:03 PM   #14
Hogger13
There is a very easy way to get into the trailer.
Please call for the instructions at 800-8777311.
I will not post the info because a thief would grab it immediately.
