Old 05-28-2016, 11:14 AM   #1
1999 25' Safari
Cincinnati , Ohio
Exterior Door Hinges Sagging
My door sags and hinges wont stay tight. Any advise welcome. 1999 Safari.
Chazblank is offline   Reply With Quote
Old 05-28-2016, 01:13 PM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I am not familiar with 1999 doors, but if the screw threads are good, Locktite will keep the screws tight.
Superat stultitia.
J. Morgan is online now   Reply With Quote
Old 05-28-2016, 02:29 PM   #3
la nomade's Avatar
2018 22' Sport
stanfordville , New York
my door was sagging,i cut open 2 or 3 metal rings,like small washers,and inserted them while someone was propping up the door,hammering them in gently...no problem ever since....
la nomade is offline   Reply With Quote
Old 05-31-2016, 09:46 AM   #4
1999 25' Safari
Cincinnati , Ohio
I like the idea of adding some shims to the hinge. What material did you use. I was thinking of looking for some small brass washers to try.
Old 05-31-2016, 01:21 PM   #5
dznf0g's Avatar
Oswego , Illinois
I used 1/4" E-clips available at any decent hardware store. Found mine at Ace.
-Rich-
Old 05-31-2016, 02:54 PM   #6
Senior Member
sheriff1's Avatar
2014 30' Flying Cloud
Sparks , Nevada
"C" clips?
2015 F350 CC 4X4 6.7 Diesel
2010 27FB Silver Cloud "The Silver Spoon"
sheriff1 is offline   Reply With Quote
Old 05-31-2016, 03:46 PM   #7
dznf0g's Avatar
Oswego , Illinois
E-clips, like this:
https://www.fastenal.com/products/fa...E-Clips%22%7C~
-Rich-
Old 05-31-2016, 07:30 PM   #8
Senior Member
sheriff1's Avatar
Sparks , Nevada
I learned something today!
Thanks!
Old 06-02-2016, 08:45 AM   #9
1999 25' Safari
Cincinnati , Ohio
Uh-oh
I removed one of the Phillips head screws to replace it with an hex head thinking I could get it tighter, and add locktite. When I tried to put the screw back in, nothing to screw it into. I'm guessing there was a nut behind the door frame that dropped. Has anyone used a rivet nut to repair this situation. Any other ideas are welcome.
Old 06-02-2016, 09:04 AM   #10
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Could you maybe carefully carefully cut a hole in the inner skin with a hole saw at the right location in order to install a new nut and then plug teh hole with a plastic plug - I think they are available in many sizes. (or cover the hole by some other decorative means.
If so, you could the easily access the nut again if you ever had to do so.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 06-02-2016, 11:05 AM   #11
1999 25' Safari
Cincinnati , Ohio
I found an older post and that was the solution they came up with. I think I'll try that. These hinges have been a source of frustration for some time.
1964 door in a Door entry door hinges recycled Windows, Doors, Locks & Vents 1 09-18-2013 06:07 PM
Exterior Door Hinges HowieE Doors & Locks 7 11-09-2012 12:13 PM
Exterior Door Hinges LKappenman Doors & Locks 25 11-09-2012 11:30 AM
Shower Door Sagging When Opened. safari 28 General Interior Topics 0 03-06-2008 12:23 PM
Sagging Door in '92 300LE fangthorpe Airstream Motorhome Forums 3 12-30-2003 02:02 PM
