Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Exterior Storage Compartments & Access Doors
Old 11-24-2003, 06:19 PM   #1
Navigator
Profile:
Exterior Compartment Locks.
Wow is me. On the way to the DMV, the refrigerator access door fell off and the guy behind me ran over it. Straightened it up as best as I could, but the lock got squashed. The casting says "Chicago Lock Co." and a #4260-1
A Google search for Chgo. IL turned up a blank.
Does anyone know if they are still in business somewhere else, or where I could get replacements?
Thanks in advance.
Dick
Navigator is offline   Reply With Quote
Old 11-24-2003, 06:34 PM   #2
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
These locks are still available form an Airstream dealer. I want to say they run like 30 bucks.
You might try to get a whole salvage door for the cost. Try Colaws.
Good luck
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 05-13-2005, 11:14 PM   #3
Smokin Camel
Profile:  1972 25' Tradewind
Madison , Wisconsin
I just ordered two new matched cores for the Chicago locks. After a lot of searching...try www.mrlock.com. They stock the 4260. Chicago lock is still in business. The new 4260 will use a round key unless you order it with out a core.
Smokin Camel is offline   Reply With Quote
Old 05-13-2005, 11:24 PM   #4
markdoane
Profile:  , Minnesota
Images: 59
These aren't the Chicago locks, but if you want any kind of lock or latch, from a glove box to bar locks for semi-trailer doors, here is the place. http://www.austinhardware.com/dept.asp?dept%5Fid=3
Non-contributing deadbeat.
Old 05-14-2005, 01:13 AM   #5
Anon
Profile:
Holy cow!
I went to the Mr. Lock site because I can use a new one on my fridge door too.
The Mr. Lock price is $12.22 for the cylinder! You can also order them keyed alike! Like the one for my battery compartment and water too! The Mr. Lock part number is: 19588
Thanks. What a great find!
Anon is offline   Reply With Quote
Old 05-14-2005, 06:36 AM   #6
balrgn
balrgn's Avatar
Profile:  1974 27' Overlander
Rockingham County , New Hampshire
Images: 74
Ooooo Nice bit of info! Great job finding it. Bookmarked for future use. THANKS!
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'77 20' Argosy MH (Peanut)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281
Member of VAC
www.balrgn.com
www.balrgn.com/Airstream.htm
balrgn is online now   Reply With Quote
Old 01-22-2006, 07:53 PM   #7
TRAPEZE
Profile:
Chicago Lock is not still in business. Their company and line was taken over by Comp X in November 1999.
http://phx.corporate-ir.net/phoenix....ular&id=102847&
Looks like they still make the cylinder replacements for the flat key t handle locks as well as the barrel type keys.
TRAPEZE is offline   Reply With Quote
Old 02-19-2006, 02:42 PM   #8
reece1107
Profile:  1972 31' Sovereign
mountain view , California
So do they work?
Has anyone actually installed them yet? They do look a little different and I don't mean just the key. Also, the water door lock is not the same type on my '72. Did or will this one work? I need a full set and want to make sure before I plop down sixty sum bux. Thanks!
reece1107 is offline   Reply With Quote
Old 02-20-2006, 02:48 PM   #9
TRAPEZE
Profile:
Yes
I just did my battery compartment, two tee handle locks, and my water door, one tee handle.
If you have the standard blade key, you will need more then just the core, as the new cylinder with the barrel type key is larger.
I ordered three of these: http://www.mrlock.com/eshop/locks/19587.html
and three of these a keyed the same: http://www.mrlock.com/eshop/locks/19588.html
Look great, all keyed the same, the barrel key feels more robust and everything just bolted in, took all of 20 min including the beer.
Scott
Old 02-20-2006, 03:14 PM   #10
Safari64
Safari64's Avatar
Profile:  1964 22' Safari
Eagle River , Alaska
I have 3 cam locks keyed differently on my '64 Safari. The key becomes the handle to open! Anyone know if I can change them out with keyed alike barrel keys? If so which MrLock parts would I use? Or perhaps just keyed alike cam locks?
Safari64
Safari64 is offline   Reply With Quote
Old 02-20-2006, 04:57 PM   #11
TRAPEZE
Profile:
Browse through this link and see if any of it will match your locks
http://www.compxnet.com/pdf/chicago0903.pdf
Old 02-20-2006, 06:30 PM   #12
Wardinbb
Wardinbb's Avatar
Profile:  1964 24' Tradewind
Big Bear Lake , California
Plenty Choices!
I used a weather resistent stainless cam lock item 13105A76 at www.mcmaster.com. They come keyed alike and I've replaced all four cam locks that were on my access doors. So far so good.
Ed
Wardinbb is offline   Reply With Quote
Old 03-11-2006, 12:05 AM   #13
sequoiacoast
sequoiacoast's Avatar
Profile:  1968 24' Tradewind
Eureka , California
Are your doors locked in place with a sliding arm? I have one lower "arm" on the rear access door... but it is not weather tight (loose gap at the top). And the other 2 door didn't have anything other than the key/lever lock at the bottom center. So these you can just pull straight out. I was thinking about hinging them maybe making a tighter seal at the top. ? Any pictures or help would be great - thanks!!
sequoiacoast is offline   Reply With Quote
