Old 07-07-2015, 03:21 AM   #1
SilverEagle6's Avatar
2013 25' Flying Cloud
2008 30' Classic
On The Road To Wherever We End Up , Traveling the USA
Door lock mechanism
I have a 2013 FC 25. Attached is a picture of the door lock. There are four screws that are constantly coming loose, this picture shows one of them. It was so bad at one point, the screw heads were jammed and we had a hard time getting the door open from the outside.
Are these bolts? Maybe the nut came off?
Am I making a mistake using loctite?
Not sure why the photo turned on me, left side is top
Jeanne and John, and always with us...Jake
2008 30' Classic Ltd Rear twin, 2014 Ford Super Duty
WBCCI 3100, unit 12, TAC USA-1, Escapees 129379
https://instagram.com/silvereagle3100/
SilverEagle6 is offline   Reply With Quote
Old 07-07-2015, 05:54 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Use a drop of blue Loc Tite on the errant bolts. I have done that on several metal to metal fastenings on my trailer. It has stopped repeated loosening.
MICHAEL
Old 07-09-2015, 08:05 PM   #3
SafariSS's Avatar
2005 30' Safari
Houston Texas , Texas
You need to grease that latch! The rust colored powder indicates its dry....i lube mine all the time and it keeps it working great. On the loose fasteners the blue loctite is the hot ticket.
SafariSS is offline   Reply With Quote
Old 07-09-2015, 09:39 PM   #4
1979 23' Safari
Wayland , New York
A little BLUE loctite as mentioned. Not the red! Should fix the loosening, single drop on the tip should do it. Work the latch a bit while it sets up so any drip out doesn't lock anything that shouldn't.
Old 07-10-2015, 05:42 AM   #5
Ron A's Avatar
2018 23' Flying Cloud
Huntsville , Alabama
Nail polish. I have had good results with nail polish on screws around locking mechanisms. If that doesn't work then I would likely go with Loctite. I'm always concerned, can I get it out if I need it to break loose. The nail polish tip came from a locksmith.
Ron
2015 Sport 16'
Ron
Ron A is offline   Reply With Quote
Old 11-16-2017, 11:36 AM   #6
2007 27' International CCD FB
San Diego , California
What do you guys use to lube the latch?
Graphite?
2007 27FB Ocean Breeze "See Turtle"
2009 Lexus LX570
pteck is offline   Reply With Quote
Changing lock mechanism on coach door. robber2711 Land Yacht/Legacy Motorhomes 6 08-23-2011 08:07 AM
Door mechanism on 1955 Safari toastie Doors & Locks 16 04-14-2010 09:22 PM
Sheared door locking mechanism upper bolt woppa 4 Doors & Locks 3 06-18-2009 08:39 AM
Lock mechanism for refer door 1978 jkrauk Exterior Storage Compartments & Access Doors 0 08-23-2008 04:58 PM
