Old 06-09-2014, 07:27 PM   #1
1968 26' Overlander
Duluth , Minnesota
Compartment Hatch Gaskets '68 Overlander
My side compartments behind the wheel wells and at the fridge appear to be a large source of leaking as the floor had the worst rot at these locations. "Gaskets" are hard plastic that fits into a groove in the frame of the hatch cover. Lots of pieces missing from gaskets.
What is the best gasket solution for this area? Can I get a gasket that goes into the groove? Is it better to put it on the frame and not the door?
ID:	213936   Click image for larger version
Bunkroom is offline   Reply With Quote
Old 06-18-2014, 09:54 PM   #2
1968 26' Overlander
Duluth , Minnesota
Any advice would be appreciated.
Old 06-18-2014, 11:43 PM   #3
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Access Door Gasket
The rubber gasket you have in the pictures is not doing any good to seal out dust or moisture. The aluminum frames of the hatches should be sealed with Vulkem, Acryl-R, or ParBond at any seams. Then a perimeter fitted gasket on the door itself or the frame made of a good grade of foam or silicone rubber to seal the door to the frame are what is needed. Foam gaskets can be found at most big box home stores in the window supply areas. They all will carry some variety of foam gaskets. Find one that fits the width of the hatch frames and apply without any cuts to corners. Start at the bottom middle of the frame or door and place the gasket completely around the facing area of the frame or door back to the bottom center to mate up with the starting edge. In my opinion a silicone rubber gasket would seal the best but might be harder to locate for the size you will need for this application. Someone else here may have a source. Do a search using the search feature here on the forums and use key words like gaskets or access door seals. Hope this helps, Ede
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 06-19-2014, 10:34 AM   #4
kokopat's Avatar
Hendersonville, NC , North Carolina
VTS has the bulb type gasket.
Hingeless Baggage Door Frame Gasket
kokopat is offline   Reply With Quote
Old 06-10-2016, 11:54 AM   #5
1968 26' Overlander
Wolfforth , Texas
compartment gasket
I am looking for the gaskets for my baggage doors, did you ever find the correct ones?
lakoria is offline   Reply With Quote
1963 rear hatch / compartment door lock Zstream Doors & Locks 8 10-01-2013 11:11 PM
Rusty ext. hatch gaskets! Del Gurney Exterior Storage Compartments & Access Doors 0 08-20-2012 01:53 PM
a Hatch, I want a hatch snkrichards General Repair Forum 4 05-17-2012 09:56 PM
Hatch gaskets... Sneakinup Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 01-26-2004 10:09 AM
