Old 03-16-2006, 03:01 PM   #1
tracker
tracker's Avatar
1969 23' Safari
crescent city , California
Question camloc
Does anyone know how to install a sring loaded camloc fastener without the use of camloc pliers? I need to replace one in my 69 safari. Carl
tracker is offline   Reply With Quote
Old 03-16-2006, 06:25 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
I have never heard of camloc pliers. My '67 Overlander uses four camloc fasteners around the bumper area, and I installed new ones during the refurb without any special tools. As I recall, a simple disassembly aided the effort (no tools required).
If you are willing to post a picture of your fastener, I am willing, if you & I have the same camloc, to go out and disassemble one of mine, and take pix, to show how it is mounted without special tools.
Tom
Old 03-16-2006, 07:22 PM   #3
tracker
tracker's Avatar
1969 23' Safari
Smile
Tom
Tom I will try to get the the pictures online by tomorrow night. thanks Carl
Old 03-17-2006, 05:40 AM   #4
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
I can usually install one with only my hands. Compress the spring with your finger and then slide the "horse-shoe" shaped catch off. Then insert spring and holder through hole and re-assemble horse-shoe catch. Simple
Old 03-17-2006, 11:18 AM   #5
tracker
tracker's Avatar
1969 23' Safari
Thanks to tom w and silverhobby with your advise I was able to get the camloc installes withiut any more problems. Thanks again. carl
Old 06-01-2009, 08:21 PM   #6
AirConditioner's Avatar
Camloc spring loaded latch install in tight quarters
I've seen a couple posts on installing these on a water heater door but only recently had to do both of mine on my 72 Overlander. One was simple, but the other which was next to the heat outlet was really too tight to use a common tool, and I don't have the special "camloc" pliers -not even sure there is such an animal. After some thinking, here's how I was able to do it without losing any parts or more hair! Hope this helps others who may inhereit this chore.
1. Remove the locking tab from the armature by compressing spring and sliding tab off at slim point.
2.Thread a nylon line thru the front of the latch armature.
3. Thread the line behind the hole and pull on cord until armature extends past hole.
4. Slip the lock tab onto the armature a few mm back from the front where the width is slightly thinner.
5. You're done!
ID:	81286   Click image for larger version
AirConditioner is offline   Reply With Quote
