Old 01-05-2015, 10:57 AM   #1
jwo9958's Avatar
Little Compton , Rhode Island
Battery compartment door hinge
I have a 1972 Overlander 27, The battery compartment door is hanging down, I need to replace the piano hinge on this, any ideas on a source for this? Thanks
jwo9958 is offline   Reply With Quote
Old 01-05-2015, 11:38 AM   #2
SteveH's Avatar
Common Sense , Texas
I replaced one on a '75 23' with an aluminum piano hinge I bought from Lowe's. Even if you found the direct Airstream replacement, you still probably have to drill new holes for the pop rivets.
Regards,
Steve
Old 01-05-2015, 12:58 PM   #3
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
I replaced the hinge on my ’72 a few years ago. I found a regular piano hinge did not fit well and caused the door to not seat in the opening.
Maybe Steve’s is different, but on mine there is a steel reinforcing plate with a ~30 degree bent in it running the length of the door. The original hinge had a bend on one side to fit the mounting area on the reinforcement.
In the end I had to mill a fixture to produce a bend into the hinge. I think I used a ĺ inch stainless piano hinge fit into the jig and shaped it on a 20 ton shop press.
Hopefully you can come up with a solution that’s not so involved.
Tom
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 01-07-2015, 10:34 AM   #4
jwo9958's Avatar
Thanks for your help guys. This hinge does have a bend in on one side. I can get that done at a machine shop that is here in my building. One other question. Aluminum or Stainless?
Thanks again.
Old 01-07-2015, 11:13 AM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Call out of Doors Mart, worth a try.
Old 01-08-2015, 10:16 AM   #6
Britbat's Avatar
1975 27' Overlander
LaVale , Maryland
Although weaker stay with the aluminum, i've an aversion to mixed metal.
Britbat & the Shiny Beast
Britbat is offline   Reply With Quote
Old 01-09-2015, 09:25 AM   #7
jwo9958's Avatar
Got it.
Got just what I need from Mcmaster. MY buddy cut it and put a slight bend in it just as the other one had. Should i use rivets to reattach this compartment cover? What should I get for rivets? One side of the hinge had rivets the other had screws that must have been used by previous owner. There is a good industrial fastener company right near me. What should I get for rivets for my AS also do I use backing washers when riveting?
Basement storage compartment hinge lubrication. BarnacleBill Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 05-03-2011 04:35 PM
Compartment door hinge/safety latch/wire rideair Exterior Storage Compartments & Access Doors 6 05-11-2010 01:24 PM
Putting Hinge on Compartment Door ayresdream Exterior Storage Compartments & Access Doors 1 04-02-2008 07:47 AM
battery compartment hinge replacement flash Classic Motorhomes 2 04-25-2007 06:03 PM
Refrigerator inspection compartment door hinge... gean235 Exterior Storage Compartments & Access Doors 8 12-06-2006 05:53 PM
