Old 05-07-2016, 05:22 PM   #1
Silverbee's Avatar
2015 28' Flying Cloud
2012 25' Flying Cloud
2007 20' Safari SE
Fuquay Varina , North Carolina
Battery Box Rust
You should check the bottom of your exterior battery box if you have one. I found the following issue on our 2015 28ft. Flying Cloud. We traded our 2012 25 ft. FC in October of 2014-so warranty end is approaching. I contacted the dealer and Airstream customer support about the issue. I expressed my concern that the batteries may someday fall through the bottom and damage our trailer or some other vehicle. The response from customer support was that the area should be wire brushed, sanded and re-painted. I did not want to take the trailer 130 miles round-trip to have this done, so decided to do it myself.
I removed the batteries to make sure that the rust had not penetrated the interior of the box. The batteries sit in a plastic tray(more about this later). There was no rust on the interior bottom of the box.
I wire brushed and sanded the rusted area and spray painted with a rust resistant gray paint. I am satisfied with the results.
In my opinion, the cause of the issue is that the plastic tray sits flush on the bottom of the box, not allowing the collected water to escape as it should. It just sits there and eventually weeps out to the bottom surface and causes rust if the paint has weakened or was not applied correctly to begin with. There needs to be space for water(from rain or washing) to flow through the escape holes. When I next have the batteries out I will put rubber feet on the bottom of the tray to create space. Perhaps Airstream will figure this out for the future. In the meantime, you should make sure you don't have this problem.
Name:	Battery box rust-Airstream.jpg
Silverbee is offline   Reply With Quote
Old 05-07-2016, 06:08 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I took the tray out of my box when I added the top extension. Gave the box a good brushing and paint when I did the rebuilt job. Recently pulled the batteries and the interior was still rust free.
MICHAEL
Old 09-08-2016, 01:56 PM   #3
PecanMan5's Avatar
2015 25' Flying Cloud
Hahira , Georgia
I am looking at a battery box on a 93 excella that totally rotted out. Where can ou get a replacement. It apparently boiled over bad and was ignored.
From my Pecan Tree
PecanMan5 is offline   Reply With Quote
Old 09-08-2016, 03:45 PM   #4
Boxite's Avatar
2008 22' Sport
Paint the interior of metal battery boxes with "battery box paint"... a rubberized, acid-resistant paint used in aircraft battery boxes.
http://www.aircraftspruce.com/catalo...ickkey=3540103
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 09-09-2016, 09:34 AM   #5
PecanMan5's Avatar
Hahira , Georgia
There is no bottom to paint.
From my Pecan Tree
I have 3 boxes of assorted parts from my airstream 59 Tradewind, I would like to sell by the box for 300.00 per box or best offer per box betsy Airstream Classifieds 0 09-19-2014 11:01 AM
Battery box and battery location(s) ehodg66 Batteries, Univolts, Converters & Inverters 4 04-22-2014 07:39 PM
Rust and Frames Por 15 Zero Rust Tony S Repairing/Replacing Floor &/or Frame 10 02-20-2013 03:45 PM
Cracker box after cracker box. rebel beck Our Community 15 06-07-2006 07:53 PM
locks for battery box and propane box Chilao Doors & Locks 11 11-02-2004 06:56 PM
