Old 12-06-2007, 06:46 AM   #1
1968 26' Overlander
Ann Arbor , Michigan
Images: 11
Back hatch cover
I need to put in some commercial undercounter refrigeration. Dont worry... I wont be traveling much with it...at least I dont think.
I cant get it through the front door or windows so I need to make a hatch to stick it through.
My focus was making a back hatch (between the lights). Between the lights...it is about 38 inches I am guessing from the looks of it. I have not taken the bathroom out yet to really know the structure of it does anyone know if this back area is an important piece to the construction of the AS.
I figured sice there is a door back there anyway...I could possibly make it big enought to stick a refer through...the refer will be about 34-36 inches high.
Aluminati is offline   Reply With Quote
Old 12-06-2007, 07:27 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Why not get an apartment sized refrigerator, if you want a standard household type unit?
They are narrower than the big ones, and should fit in the front door. It should be easier and cheaper than cutting a bigger hole somewhere to make a standard-sized unit fit.
Old 12-06-2007, 07:39 AM   #3
1968 26' Overlander
Images: 11
It has to be commercial grade...health dept wont allow that.
Old 12-06-2007, 08:10 AM   #4
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Anyone know how wide an Airstream door is...?
Old 12-06-2007, 09:18 AM   #5
Well Preserved
1993 21' Sovereign
Our Overlander's door was 28" wide at its widest point.
Old 12-06-2007, 10:15 AM   #6
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Thanks Terry.
How bout one or two of these rather than cutting the rear out of an Airstream....
Midmark Corporation Medical Equipment
Old 12-06-2007, 02:22 PM   #7
1968 26' Overlander
Images: 11
Thanks Terry.
The 68 measures 26"wide...
I need commercial refrigeration because it recovers proper temps faster.
Old 12-06-2007, 07:50 PM   #8
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Then the one in the link above should go through the door without a problem. Good luck....
'68 Overlander back hatch Aluminati 1968 Overlander 2 11-29-2007 05:47 PM
Roof Hatch flyguy Roof 7 09-16-2007 10:20 PM
Back hatch weatherstripping wacnstac Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 04-06-2006 02:58 PM
Odd back-to-back eBay auctions .... summerkid Trailer Values 5 09-12-2005 12:34 PM
