Old 05-04-2010, 05:21 PM   #1
1966 24' Tradewind
portland , Oregon
Access door in 1966 tradewind
hello,
What type of aluminum material was used to build the access doors for mid 60's. I understand that 2024 T3 is good for the skin, but not the doors.
Thank you
steverad is offline   Reply With Quote
Old 05-04-2010, 07:49 PM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
First off I'm not making fun. Is there a reason that 2024 T3 is not good for the doors? Inquiring minds want to know...
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 05-04-2010, 08:14 PM   #3
Images: 59
The doors are made in two parts. The outside skin can be 2024 T3, but first you need to form the pan that rivets to the back of the door skin. This requires some sharp 90 degree bends to form the pan, and 2024 T3 (actually more like T6 if its old) is too hard and brittle to form.
I make the pan out of whatever .025 stock is laying around, and keep the outer skin out of 2024.
ID:	101815   Click image for larger version
Old 05-04-2010, 09:20 PM   #4
1966 24' Tradewind
portland , Oregon
Lee,
I was going to build the door different. My way, I had to fold the metal & 2024 can be bent but not fold.
Thank you Markdoane for the photos.
Steve
Old 05-05-2010, 06:05 AM   #5
1967 22' Safari
1960 Caravel
Images: 8
Thanks Steve, Now I understand.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 05-05-2010, 06:30 AM   #6
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I made a door for 66 Caravel for a friend of mine, exactly like the original, which required the edges to be hemmed with no external rivets. I used 3003 aluminum
Old 05-05-2010, 05:10 PM   #7
1966 24' Tradewind
portland , Oregon
Dear Aerowood,
would 3003 polish like 2024 t3?
Old 05-06-2010, 06:36 AM   #8
Aerowood's Avatar
Arvada , Colorado
I've never tried it but it should be pretty close to the same. No alclad so it will take more time
Old 05-06-2010, 07:41 AM   #9
AirstreamGypsy's Avatar
1961 16' Bambi
Mancos , Colorado
Send a message via Skype™ to AirstreamGypsy
Mark, That looks great. Do you think a door in a door can be built as well?
And Kip, was the 66 Caravel a door in a door? And by hemmed do you mean that last 1/4 of an inch or so that is slightly rounded and curved in toward the body of the trailer.
AirstreamGypsy
___________
Charter Member FCU • WBCCI 1818 • CP(Courtesy Parking) • Wi-Fi
My Earthship
AirstreamGypsy is offline   Reply With Quote
Old 05-06-2010, 12:00 PM   #10
dnrtheil's Avatar
1964 24' Tradewind
Portage , Michigan
SEM 39537 is a two part epoxy that could be used instead of rivets if you build the door like markdoane did. This is the same epoxy that holds many automotive panels together. Most any automotive paint supplier should have this or a similar product.
Derek
Operation "SAVE RUDY" Strike Team (Associate Member)
dnrtheil is offline   Reply With Quote
1966 Rear Access door & Aluminum rain gutters steverad Exterior Storage Compartments & Access Doors 4 01-27-2010 11:49 PM
Fridge for a 1966 Tradewind SterShreve Refrigerators 6 05-05-2009 11:27 AM
Access door for a '61 Tradewind CLAD 1959-69 Tradewind 7 06-22-2008 11:40 AM
1966 TradeWind 66TradeWind 1959-69 Tradewind 2 03-18-2002 07:09 AM
