Old 07-31-2012, 09:17 AM   #1
1964 22' Safari
Albuquerque , New Mexico
'64 Safari compartment door
Lost a door on my trip to Gunnison colo.. any one knows where to find one.?
SPasquale is offline   Reply With Quote
Old 12-06-2012, 05:43 PM   #2
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Did you ever find your door.
I just saw and for doors at Vintage Trailer supply
desertair27 is offline   Reply With Quote
Old 12-06-2012, 05:52 PM   #3
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
Or Inland. The rear compartment? I just got the three point latch for the rear door from VTS, because the latch was so iffy and I was afraid to lose it.
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 12-06-2012, 08:03 PM   #4
Many owners have lost the rear "one stop center door".
Why, this time, has two answers.
1. It was not inserted into the top groove or latched properly.
2. Rear end separation. That will cause the riveted frame to expand vertically, which then simply lets the door fall out when hitting a bump.
Is there an easy fix??
Yes, indeed.
Attach a couple of lengths of very small chain to the inside top of the door and then to the inside top of the door jamb.
Keep the chain short enough so that the door when opened will hang below the jamb. That also keeps it from hitting the ground.
Old 12-14-2012, 09:10 PM   #5
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
I heard inland rv has reproduction doors but I meant to say VTS has this extrusion allowing you to build your own doors.
http://www.vintagetrailersupply.com/..._p/vts-869.htm
I'm working on my first door but I'm have a hard time with my miters.
Old 12-14-2012, 09:20 PM   #6
Hingeless Baggage Door Frame Extrusion
The bulb gasket though, was OK some 45 years ago.
Today, it's not even good enough for a paper weight.
The "D" shaped gasket, leaves the bulb type gasket, way back in the dust.
Old 12-14-2012, 11:38 PM   #7
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Here's my first attempt. Far from perfect but I think I may have it figured out for the next door. Getting the miters right is tough.
I didn't know about the bulb gasket, maybe I can fit a D shaped gasket in there.
Compartment door to hide damage to skin Kristi Foster Exterior Storage Compartments & Access Doors 1 11-08-2011 05:17 PM
Dometic RM3804 Butter Compartment Door DesertStream Refrigerators 3 08-27-2011 09:24 PM
Battery Compartment Door Leak McDonalds Exterior Storage Compartments & Access Doors 4 06-28-2011 08:52 AM
My battery compartment door fell off DougZ Exterior Storage Compartments & Access Doors 0 06-05-2011 07:05 PM
Need Refrigerator Compartment Door for 1972 Overlander jazz1945 Exterior Storage Compartments & Access Doors 1 05-30-2011 03:50 PM
