Old 03-07-2011, 07:39 PM   #1
1962 22' Safari
Tuscaloosa , Alabama
'62 Safari door latch puzzle
My wife and I bought our first Airstream last week, a 62 Safari. I'm attaching photos of the odd door latch situation. A prior owner has removed whatever was in the rectangular hole and installed a smaller flush-type latch that fits poorly. Apparently new holes had to be cut out of the door and door frame. The lock that was previously there measured 3 1/2" by 8", and was mounted in a 3 1/4" by 7 1/4" hole. Does anyone know what has happened here, and if so, what's the best way to fix or improve it
ID:	123926   Click image for larger version
Name:	edge of door.jpg
ID:	123928   Click image for larger version
Name:	door opening.jpg
vknight is offline   Reply With Quote
Old 03-08-2011, 07:57 AM   #2
That hole in the door says that the trailer door, at least, belongs to a 1970 to 1977 Airstream trailer.
The original lock was call "KT".
Someone tried to install the Bargmann L-400 lock, which will not work correctly.
Post the trailer serial number for a positive ID.
Some lock kits are available, that are far cheaper than the several hundred dollar KT lock, but it depends on the year of the door.
Old 03-08-2011, 08:35 AM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Wrong Door Lock
Can you post a picture of the hinge side of the door? It will help ID the door. Also the hole in the door is obviously too large for the door handle assembly. It's hard to tell what was there before or even if that was original.
Old 03-08-2011, 08:15 PM   #4
1962 22' Safari
Thanks, with more door pics
Many thanks for the help. Attached are some more door pics, inside and outside. Naturally I'm surprised if this is really a post-1970 door on what is supposed to be a 62 Safari. I can't find a plate with the serial number anywhere on the trailer. However, one of the older tag receipts in the paperwork lists the serial number as TSS0981. Any help on the correct ID, plus how to improve the situation, are appreciated!
Name:	door outside.jpg
ID:	124012   Click image for larger version
Name:	door inside.jpg
Name:	door inside w screen.jpg
Old 03-08-2011, 10:04 PM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
??????? Safari
I'm not sure, but I don't think you have what you think you have. Here is a photo of what I think is a '62 Safari. Maybe someone can help with the ID of you trailer. The thing that stands out to me is the '62 has a door within a door and it's hinged on the right side not the left.
Old 03-08-2011, 10:06 PM   #6
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The door looks to be from a 70-72 because of the big single hinge. The trailer looks like a 62 Flying Cloud and the numbers are close to that, but the Safari also shared the same numbers. The original door for a 62 would have been the door in a door.
Richard
Old 03-08-2011, 10:29 PM   #7
Yhottys's Avatar
1960 24' Tradewind
1961 16' Bambi
Oakland , California
Jim,
Welcome to the Forums and congratulations on your "new" Airstream.
You might find the following link helpful. It's from VintageAirstreams.com and is a photo archive of 1962 Airstream Safaris. 62Safari
The original door had a door within a door, as others have pointed out. It also had a lock with a square escutcheon and round door knob, similar to the image below.
Good luck with your project.
Gemma and Murray
Yhottys is offline   Reply With Quote
Old 03-08-2011, 10:42 PM   #8
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
More questions
Here's another photo of a '62 Safari. Door hinges on the left, but is also a door within a door, but it is round on the top. Your door is flat on the top, more like those in the '70's. Your trailer also has round wheel well cut outs, where both of the Safari's I've posted are square.
Old 03-09-2011, 03:22 AM   #9
Baltimore , Maryland
Is that an Avion? The door looks so odd. this serial #, did it come off the title or trailer? A title has the date wrong 50% of the time. The serial number should be close to the door on the "Airstream" plate.
Old 03-09-2011, 07:01 AM   #10
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
69 or new door hinge also. Interesting that there is a jelousie window, and appears to be early 60's shell shape and seams. Wondering if someone repaired side damage and had early 70's parts? Also appears badges by the door are missing.
our 63 has flat topped, but rounded corner wheel wells also (and yes this pic is a pre-axle swap photo)
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 03-09-2011, 08:49 AM   #11
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Another photo
Here's a pic of a '64. It has a window forward of the door (larger than yours)but still has a round top door. I'm not sure where you need to look for the VIN. Can you post pics of the whole trailer and are you sure of the length? Measure from the hitch ball socket to the rear bumper.
Old 03-09-2011, 06:41 PM   #12
1962 22' Safari
Name that Airstream!
We have gone from my door latch issue to not knowing if my airstream is really a 62 Safari as advertised, maybe not a Safari at all, or maybe one that has had major restoration on the door side with post '70s hardware. Okay, so here are photos of the whole girl from several angles. Again, the only info I have on a serial number is TSS0981, which comes from a 1991 bill of sale, where is is called 8' by 22'. The actual measurement from center of hitch ball to outside of back bumper is 22" 10". Again, thanks, folks.
ID:	124088   Click image for larger version
ID:	124090   Click image for larger version
Old 03-09-2011, 06:54 PM   #13
Central , Mississippi
To me, it looks like a later year door has been installed but I can't see any evidence of the door-in-a-door hinges...
'65 or later with 'some work done'?
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 03-09-2011, 07:10 PM   #14
This definately has the shape of a 70's door and runoff gutter above. Here is our 79' door (best shot of the whole door frame):
Our '56 Safari (aka Our Retirement Home) SafariSteve 1956 Safari 41 09-04-2013 05:55 PM
1968 Safari 22' :: 1968 Airstream Safari Darrengj Airstream Registry Discussions 0 08-19-2011 08:32 AM
Safari :: 2006 Airstream Safari SE Mrs Silverback Airstream Registry Discussions 0 08-19-2011 08:31 AM
New Safari owner 2001sport 1966 - 1968 Safari 10 06-24-2011 11:30 AM
