Old 10-03-2011, 07:13 AM   #1
Ridgerunner3's Avatar
2002 25' Safari
Fountain Inn , South Carolina
Images: 13
'02 Safari Door Gasket Install Help Needed
I need to install a new entrance door gasket on my 02 Safari. The present gasket is the wrong gasket and does not do the job. I am ordering the proper gasket and I know to use both the sticky back and the good black gasket adhesive.
Does the door gasket go all of the way around the door? Do you cut and miter the corners for under the door or is it one continuous loop around the door?
Any pictures of a properly installed door gasket on this vintage door would be greatly appreciated.
Bud
Ridgerunner3 is offline   Reply With Quote
Old 10-03-2011, 08:48 AM   #2
Bud
The entrance door gasket "must" go all the way around the door, with the seam at the bottom.
The proper adhesive is 3M8008, which is black.
DO NOT use the 3M yellow adhesive as it's not strong enough.
Old 10-10-2011, 05:49 PM   #3
2002 25' Safari
Images: 13
I have the new door gasket and the correct 3M adhesive. My door did not have the proper gasket installed previously so I have no idea what a properly installed door gasket should look like. I have read many threads about door seals and door gaskets. I am one of those people who really needs a picture of a properly installed door gasket. I have not been able to find a picture of a properly installed door gasket. Can anyone share a picture of a properly installed door gasket?
Bud
Old 10-10-2011, 06:17 PM   #4
Bud
That gasket is triangular shaped.
The white part is mounted to the door sheetmetal.
The gasket rests against the sheet metal and the door framing.
Apply some adhesive to the white side of the gasket, and to the backside of the door sheetmetal.
Allow that to dry for about 10 minutes, and then install it. Use caution when installing it since once you place it against the door, you will not be able to move it.
Start at the center of the bottom of the door, and go around the top. At the bottom, overlap the gasket about 1/8 of an inch. Apply adhesive to both ends of the gasket. After 10 minutes, stick the 2 ends together as well as against the sheet metal.
That in effect gives you a solid gasket, with no cuts, or seams.
Photo's won't show you that procedure.
After the installation is complete, spray the gasket with silicone spray and shut the door. Leave the door shut for a couple of hours to allow all the adhesive to properly bond the gasket to the metal.
Old 10-10-2011, 07:37 PM   #5
2002 25' Safari
Images: 13
Andy, thank you. You are real asset to this forum. You have made the installation instructions very clear.
Our '56 Safari (aka Our Retirement Home) SafariSteve 1956 Safari 41 09-04-2013 06:55 PM
Onan install – ’05 30’ Classic GetOutDoors Generators & Solar Power 16 09-10-2012 07:59 AM
Safari :: 2006 Airstream Safari SE Mrs Silverback Airstream Registry Discussions 0 08-19-2011 09:31 AM
New Safari owner 2001sport 1966 - 1968 Safari 10 06-24-2011 12:30 PM
1978 23' Safari International info needed ktmmike1 1974 - 1979 Safari 4 01-19-2011 12:07 PM
