Old 05-26-2015, 06:30 PM   #1
gomotomoto's Avatar
Longport , New Jersey
Zip Dee awning partly out of the track
About 12" of our awning is starting to come out of the track. Do I have to take the whole thing off to repair, or does anyone know a way to get it back in the track without removing it?
It seems a piece of the the rubber (pencil shaped) part that holds the awning in the track has come out due to the threads unraveling.
gomotomoto is offline   Reply With Quote
Old 06-10-2015, 07:28 PM   #2
gomotomoto's Avatar
Fixed with a small length of surfboard leash
Old 06-10-2015, 10:04 PM   #3
dznf0g's Avatar
Oswego , Illinois
Wow! I just noticed this on mine the other day. Tell more about how you fixed. Please
-Rich-
Old 06-11-2015, 05:22 AM   #4
gomotomoto's Avatar
I simply folded the awning over the leash cord and stitched it up with some thin waxed cord. I popped the part that came out back in and carefully squeezed the track together.
Worked like a charm.
Old 06-11-2015, 06:52 AM   #5
dznf0g's Avatar
Oswego , Illinois
Still not sure I understand. Mine still has the fabric intact. It appears that the fabric, along with the "cord" has just pulled out of the track about 6", located about 5 feet from the rear end. I tried to pop it back in, but it fought back. I need some methodology, of tool, that reduces the chance of slipping off the cord and damaging the skin.
Also how do I pinch the track so far from the end of the fabric? I am afraid of hammering, for obvious reasons, and pliers won't reach?
-Rich-
Old 06-11-2015, 06:59 AM   #6
CRH
1995 25' Excella
xxxxx , xxxxxx
You need to open the slat a bit with channel locks to get the cord back in. Then, you need to tap the slat back closed with a rubber mat....Unfortunately, the best way to go about it is with the fabric and one slat off the trailer. Taking it off is not difficult. It is a two man job. Zip Dee has the instructions on their site.
CRH is offline   Reply With Quote
Old 06-11-2015, 07:04 AM   #7
dznf0g's Avatar
Oswego , Illinois
Could it be opened from the roof and tapped back down? No room under the awning with in installed due to the curve of the skin and angle of awning. I'd LOVE to avoid removing the awning.
-Rich-
Old 06-11-2015, 07:08 AM   #8
CRH
1995 25' Excella
xxxxx , xxxxxx
It has to be opened from the bottom....I just took the awning off my trailer to have it restitched. It wasn't difficult.
Old 06-11-2015, 07:11 AM   #9
dznf0g's Avatar
Oswego , Illinois
So would it be easier to take down the whole assembly, or un-rivet the fabric from the roller and just slide out the fabric?
-Rich-
Old 06-11-2015, 07:14 AM   #10
CRH
1995 25' Excella
xxxxx , xxxxxx
If you have enough helping hands, it would be easier to leave the fabric on the roller and slide the last slat out.
Old 06-11-2015, 07:16 AM   #11
dznf0g's Avatar
Oswego , Illinois
Or....why couldn't one just remove the retaining screws from the aluminum road cover slat, and remove the fabric connector and one of the cover slats only?????
I don't have any helping hands around here anymore....not often anyway.
-Rich-
Old 06-11-2015, 07:21 AM   #12
CRH
1995 25' Excella
xxxxx , xxxxxx
You only need to remove the last slat....the one the fabric is in....The reason for 2 or more helpers when taking it off with the fabric on the roller is because it is heavy and awkward. If you drop it partially off, you will ruin the slat.
Old 06-11-2015, 07:26 AM   #13
dznf0g's Avatar
Oswego , Illinois
OK, what did you do about the roller spring tension? Just muscle it down with helpers and weight it down or something?
-Rich-
Old 06-11-2015, 07:29 AM   #14
CRH
1995 25' Excella
xxxxx , xxxxxx
Mine was opened. I unwound it with the rear arm....I would assume if you have a lock, the spring won't unwind when you take both heads off.
Partly removing center ceiling, possible? Valacidor General Interior Topics 4 09-18-2013 05:53 PM
RELAX 12v AUTOMATIC AWNING RETROFIT KIT by Zip Dee for Main Awning LaBigDogs Awnings 12 07-30-2013 03:02 PM
Will a Zip Dee awning fabric fit on Dometic Awning tube? montanablue Awnings 2 10-24-2011 11:27 AM
1973 airstream rv 31' excella500 partly restored titled eBay Watch Airstreams on eBay 0 11-01-2009 07:20 PM
Zip Dee up or Zip Dee down? highsidepass Awnings 24 11-17-2007 09:12 PM
