Old 06-11-2015, 06:30 AM   #15
dznf0g's Avatar
Oswego , Illinois
If you're talking about the z-lock, mine doesn't have it.
-Rich-
Old 06-11-2015, 06:33 AM   #16
CRH
1995 25' Excella
xxxxx , xxxxxx
Then, the spring will uncool when you take the rear head off.
CRH is offline   Reply With Quote
Old 06-11-2015, 06:34 AM   #17
dznf0g's Avatar
Oswego , Illinois
OK, I'm getting the picture now. I'll have to invite the boys over for a "barbeque" and "spring" this on them when they get here.
Thanks for the help, I appreciate it.
-Rich-
Old 06-11-2015, 08:45 AM   #18
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Be careful! The spring holds a lot of tension. You will need to unwind it to release the tension using the arm before you take it off. Zipdee can give you instructions if you email them.
When the awning is installed, the slats are installed on the trailer first, then the awning and last slat are slid in. It took us 3 people to install ours start to finish. (21 ft awning) The arm is wound at the end. We didn't get enough tension on ours the first time around and that's why the wind almost claimed her on I70 last spring. You need enough tension to wind the awning up with a finger push but not so much you have to hold it down when you open it.
Good luck!
Kay
Old 06-11-2015, 09:34 AM   #19
dznf0g's Avatar
Oswego , Illinois
Instructions here:
http://awningsbyzipdee.com/media//DI...1dffffd523.pdf
28 turns for mine
-Rich-
Partly removing center ceiling, possible? Valacidor General Interior Topics 4 09-18-2013 04:53 PM
RELAX 12v AUTOMATIC AWNING RETROFIT KIT by Zip Dee for Main Awning LaBigDogs Awnings 12 07-30-2013 02:02 PM
Will a Zip Dee awning fabric fit on Dometic Awning tube? montanablue Awnings 2 10-24-2011 10:27 AM
1973 airstream rv 31' excella500 partly restored titled eBay Watch Airstreams on eBay 0 11-01-2009 06:20 PM
Zip Dee up or Zip Dee down? highsidepass Awnings 24 11-17-2007 08:12 PM
