Go Back   Airstream Forums > Airstream Community Forums > Our Community
Old 06-29-2009, 08:17 AM   #1
Profile:  1976 21' Globetrotter
chanhassen , Minnesota
WTB - Small # of Olympic Rivets 5/32"
Fellow Airstream Enthusiasts,
I've been updating a '76 Globetrotter - I want to replace the skylight windows as they're deteriorated.
Do any of you have a small inventory of 5/32" Olympic Rivets that I can buy? I only need @ 50 or less. I can buy them from Vintage Trailer Supply if need be but will have more than I need. Is it possible to use a Dremel to grind down the point or do I need to invest the money in the tool they recommend?
It looks to me that the ONLY way to remove the glass skylights is by drilling out the rivets from the exterior.
Thanks so much,
Ken Tuvman
kentuvman is offline   Reply With Quote
Old 06-29-2009, 08:59 AM   #2
Profile:  1977 27' Overlander
1963 19' Globetrotter
naples , Florida
I`m sure somewhere down the road you are going to need more,I think maybe Inland RV sells them by the piece.If you take your time you can get them to look decent with a roto zip.That tool is expensive.Dave
easyride is offline   Reply With Quote
Old 06-29-2009, 09:02 AM   #3
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Buy 100...you'll need more than you think & by the time you buy 50 individually +shipping - you'll spend about the same as the 100 will cost. Better pricing per rivet on a hundred. I know the dealership by me sells them individually for $.79!!!
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
Old 06-29-2009, 09:22 AM   #4
tphan's Avatar
Profile:  1972 27' Overlander
estes park , Colorado
I believe Outofdoorsmart (something like that, anyway) has them for a good deal, try their website.
tphan is offline   Reply With Quote
Old 06-29-2009, 09:47 AM   #5
Commercial Vendor
Profile:  Corona , California
Thanks so much,
Ken Tuvman
Do not attempt to install the vent covers with Olympic rivets.
They will crack the plastic.
Use soft aluminum pop rivets.
When you do use Olympics, do not use those that have a washer. In time, that washer fails, leaving you with a loose fitting, that also will leak.
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 06-29-2009, 10:26 AM   #6
InsideOut's Avatar
1956 22' Safari
Images: 87
We got ours by the 100's from VTS - looks like they are $22.85 per 100 right now ~
Shari
Old 06-30-2009, 10:47 AM   #7
Here is a picture of what I'm trying to say
These are the rivets holding in the skylight glass that has deteriorated.
I am guessing the rivets holding the aluminum frame are Olympic rivets.
Am I correct?
Thanks again,
Ken Tuvman
Old 06-30-2009, 11:19 AM   #8
Commercial Vendor
Am I correct?
Thanks again,
Ken Tuvman
Yes, your correct.
Use Vulkem as a sealer, between the window frame and the sheet metal.
Andy Rogozinski
Inland RV Center
Corona, CA
Buck rivets or Olympic rivets? Sparkygus Ribs, Skins & Rivets 20 02-28-2009 09:33 AM
olympic rivets, small quantities? goransons Ribs, Skins & Rivets 2 09-28-2008 03:53 PM
Olympic Shaved Rivets vs. Buck Rivets with Dimple msjaarda Ribs, Skins & Rivets 8 03-16-2007 11:00 PM
Shaver Tool for 5/32" Olympic Rivets BB 55 Bubble Ribs, Skins & Rivets 21 03-05-2006 07:19 AM
