Go Back   Airstream Forums > Airstream Community Forums > Our Community
Old 07-05-2003, 08:52 PM   #1
Why not a 34' or a 31' ?
Do certain things get a LOT harder at certain lengths?
For instance:
Is backing harder?
Is towing harder?
Is access to certain national parks, etc. harder?
Are heating / cooling harder?
I'm not quite sure how to ask this question... Is there a 'sweetspot' in the longer lengths? Like is 34' just too long for bad roads?
How about asking it this way...
Any significant downsides to jumping from 28' to 31' ?
Any significant downsides to jumping from 31' to 34' ?
just starting to search!
darkStar is offline   Reply With Quote
Old 07-05-2003, 10:07 PM   #2
Midamrail's Avatar
1975 Argosy 26
Villa Ridge , Missouri
DarkStar,
As the owners of both a 31' Sovereign and a 24' single-axle Tradewind (and, for a brief time, a 17' Caravel), we have had experience with both sides of the coin.
Our Sovereign is a joy to own and extremely comfortable. In fact, we've often noted that we could live in it comfortably for a period of time if we ever decided to build a house or were caught between houses. We could not say that for the Tradewind. However:
- we wouldn't consider pulling the Sovereign with anything but a 3/4 ton truck or SUV with a long wheelbase - we have a crew cab long bed Ford truck for our primary tow vehicle
- we can't park it in our driveway before trips and have to back it all the way down our dead-end street. It stays in storage except for trips.
- there are several state parks in Missouri at which we can't camp with it due to its length
- everything is a consideration with it - i.e. what gas stations we can use, what exits and streets we can take in larger cities, where we can and can't turn it around
- backing is a learned art and isn't all that bad with the larger trailers. In fact, it can be easier than the short single-axles that are prone to jackknifing
- it's more prone to sway in high winds
- it tends to drag on dips
But the Tradewind:
- fits in the driveway
- isn't even noticeable behind either of our trucks, even the single-cab
- is really easy to back
- fits in nearly any campground, even most state and national (though the cut-off for some is 22 feet)
The bottom line is that a 31' or 34' is manageable with the proper tow vehicle, a good hitch system, and attentive driving combined with practice and experience. But know going into it that there's a tradeoff. For the extra room you get inside (and you'll undoubtedly use that extra room), you'll have to put up with a certain amount of challenges and limitations that you wouldn't have with a smaller trailer. If you're taking shorter trips (less than a week) to state parks, go with the smallest trailer you can live with. If you're taking longer trips or staying in private campgrounds, go with a more comfortable trailer. Just make sure your tow vehicle and hitch system are up to it.
Both Alex, my Argosy, and I are kids from Versailles, Ohio!
Midamrail is offline   Reply With Quote
Old 07-06-2003, 01:39 PM   #3
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
We started big, with a 31' SLY. I tow with a 1 ton (9200 GVW) pickup, with big block gasoline engine. Being a "farm boy" I have no problems backing it in anywhere. Have not been to a campground yet, that it would not fit into. (Ohio, Indiana, Pennsylvania). Wife likes the large coach. If we ever decide to get something different, it may be a 34' tri-axle.
The tent campers next to us, this weekend, said we had a "Cute little trailer".
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Length related problems: 29' vs 32' & 34' femuse Our Community 4 04-27-2015 12:07 AM
34' Slide Out and Factory Tow Package - 2002 Classic jcanavera 2001 - 2005 Classic 17 06-30-2003 10:25 AM
Weight 1987 34' Excella 83Excella 1987 - 1989 Excella 6 03-26-2003 06:43 PM
