Old 03-11-2004, 01:36 PM   #1
Where to get keyless entry code?
I have an airstream with exterior keyless entry. The previous owner lost the code. I understand ford designed it. Call Ford?
Airstream?
Maybe there is a trick
Rick
0557 is offline   Reply With Quote
Old 03-11-2004, 02:13 PM   #2
Elgin , Texas
Images: 164
I would think that there would be some means of resetting it to some kind of a default, then changing it to a new combination from there. Being as your Limited is still not very old, might there be some chance that the dealer who sold it new might have a copy of the original paperwork, including the combination? Or maybe get a hold of someone savvy to the 60th Anniversary edition at Jackson Center who might know if they were programmed there or came pre-coded from the lock manufacturer (Ford presumably). If they were programmed at Jackson Center it's not beyond the realm of possibility that there is someone there who knows how it's done.
BTW, if that Limited is the one I think it is, you bagged yourself a sharp-looking rig!
bake315 is offline   Reply With Quote
Old 03-11-2004, 03:05 PM   #3
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
Code card...
Rick... FWIW, ours has a small card taped to the inside of the cabinets over the couch with the code on it. We also have all of the original paperwork, as we bought our Ltd from the original owners. I'll check it when I get a chance and see if there's anything in it that might help you.
Roger
Old 03-11-2004, 03:56 PM   #4
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
Red face Reset
There is a master code that never changes. You enter the master and then you set up lock systems and user pass codes. On mine you can set up more than one user pass code.
The manual tells you the master and the procedure for changing it.
I suspect that AS tech support can give oyu info on it.
I will look in manual and get back to you.
Smily
smily is offline   Reply With Quote
Old 03-11-2004, 06:25 PM   #5
donnall's Avatar
I emailed Airstream, they ask for my ser# and some other info, then they sent me the master code.
HTH
Don
Don Nall
93 Land Yacht (The Minnow)
donnall is offline   Reply With Quote
Old 03-11-2004, 06:28 PM   #6
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Keyless door code SHOULD be a five digit number. Look for this inside cabinet doors, and on the inside of the main door hinges.
Old 03-15-2004, 09:48 AM   #7
Send a message via Yahoo to silver suz
keyless door locks
Has anyone installed a keyless pad on a 1971 (or old) AS? How did you do it? Thanks ,sliver suz
silver suz is offline   Reply With Quote
Old 03-01-2010, 08:43 PM   #8
1990 36' Land Yacht
whitewater , Wisconsin
also looking for help with keyless entry
Hi, I found all of the info you guys posted helpful. I found a 4 digit code on an airstream tag inside my main door. Did Airstream use a 4 digit code on older models, mine is a 90. If so, does any one have instuctions available to set up pass codes?
sam12776 is offline   Reply With Quote
Old 03-01-2010, 09:33 PM   #9
it's Easy to find
On mine it's located in the conduit box mounted on the wall
inside the storage compartment underneath the curbside couch arm
"goucho". Unscrew the cover and a 5 code label should be on there.
Mine is a 91 limited.
Old 03-02-2010, 08:02 PM   #10
1990 36' Land Yacht
Thanks for the info, I will try to look tomorrow. I'm kind of ignorant when it comes to the lingo, not sure what the curbside couch is. But I'll try taking a look in all the outside storage compartments. Thanks again.
Old 03-02-2010, 08:04 PM   #11
1990 36' Land Yacht
just read your post again, is in in the compartment under the couch?
Old 03-03-2010, 12:10 AM   #12
Ottawa , ON
Fyi:
If you parked your trailer (TT) properly on a city street, the curbside is the side of the TT nearest to the curb.
The other side is then the "streetside".
Never be too shy to ask... We aim to please!
Old 03-03-2010, 12:15 AM   #13
Ottawa , ON
Fwiw
Someone mentioned that the AS keyless entry is made by Ford.
Our Ford TV has it, and for you other Ford owners out there (if you have keyless) there number is printed on a small paper label only visible if you get on your back on the floor under the steering wheel.
I would find it a very useful feature, if I could only remember the number...
Old 03-29-2011, 02:20 PM   #14
I'm glad everyone is finding there codes.
Sorry I haven't responded lately.
Cheers Rick
found my keyless entry code! 0557 Doors & Locks 2 01-10-2011 12:45 PM
Keyless entry Tarheel Doors & Locks 0 05-02-2007 07:32 PM
Keyless entry poqn2slots General Motorhome Topics 2 09-10-2004 09:07 AM
Keyless entry grogan Doors & Locks 2 04-20-2004 12:16 PM
Keyless Entry r doghse Doors & Locks 5 12-09-2003 12:20 PM
