Old 01-06-2016, 08:21 PM   #15
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Is there an automatic setting?
If so use it.
It will automatically run the heat pump until it is too cold then switch to propane furnace.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 01-06-2016, 08:29 PM   #16
greghoro's Avatar
2013 25' Flying Cloud
Wheaton , Illinois
Like Kelvin (KJRitchie), I put it in Heat Pump mode only when I am away. Too noisy when I am in the trailer.
When in furnace mode, I use a portable electric heater (Vornado DVTH) to supplement it.
When camping in cold weather, the furnace brings the inside up to temperature faster than the heat pump. You can also run the furnace when traveling, although I have not done so and can't comment on that practice.
Greg
greghoro is offline   Reply With Quote
Old 01-07-2016, 04:09 AM   #17
m.hony's Avatar
2013 30' Classic
It is noisy, by warm.
When I am plugged up at a campground, heat pump costs no more.
If I run furnace, I'm using my propane that I had to buy.
For this reason I use water heater and refrigerator when on shore power too.
TAC #MS-10
Airforums #70955
Old 01-07-2016, 04:26 AM   #18
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
I use the furnace for any temp below 50 degrees F, above that I use the HP. Heat Pumps are simply taking outside air and "running" it by an electric heat strip and blowing it into the trailer. They are not designed to be efficient below 45 degrees F. Aside from the propane use I prefer the furnace.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 01-07-2016, 04:28 AM   #19
m.hony's Avatar
2013 30' Classic
But the heat pump will still warm down into the 30's until it becomes useless-
TAC #MS-10
Airforums #70955
Old 01-07-2016, 07:16 AM   #20
dznf0g's Avatar
Oswego , Illinois
Not quite. They take inside air and blow it over the evaporator (when A/C is used) which is now the condenser, in HP mode. The unit effectively runs backward, relative to the flow of refrigerant....thus absorbs heat from the outside air....down to about 38* with my particular unit. It then will switch to furnace operation automatically, if you program the CCC properly.
Read here: http://www.achrnews.com/articles/928...e-of-operation
-Rich-
Old 01-07-2016, 07:42 AM   #21
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Because I have a split system A/C
Originally Posted by cazual6 View Post
Why is that exactly?
Look at my other threads for details. This system uses very little current (6 amps or so) and is very quiet.
BambiTex is offline   Reply With Quote
Old 01-07-2016, 07:49 AM   #22
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Not sure what is in my profile
Originally Posted by Foiled Again View Post
Dear BambiTex - looked at your profile... Unless you've replaced the units, wouldn't you have heat strips rather than a heat pump?
My first - a 2005 - had heat strips (electric heating elements same as a space heater) rather than a heat pump (reversible a/c which pumps heat OUT in summer and IN in winter.) Even as recently as 10 years ago heat pumps were rare on trailers - but the technology has improved greatly since then.
Paula
I installed a residential "inverter style" split system air conditioner with the compressor mounted on the tongue. It is also a heat pump (reversible A/C) and runs very quietly and uses about 6 amps. Very pleased with it. Kept the trailer cozy warm in the Grand Canyon with outside temps in the 30's.
Old 01-07-2016, 09:23 AM   #23
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Posting a comment about how quiet your heat pump is without explaining that you have a non-standard set-up is misleading and not at all helpful. Expecting people to pour through your "other threads" to get the background is unrealistic.
Bob Martel
WBCCI# 5766
Old 01-07-2016, 09:39 AM   #24
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Fair enough
Here is the thread:
http://www.airforums.com/forums/f427...-c-138831.html
Old 01-09-2016, 01:04 PM   #25
2000 30' Excella
2014 30' Classic
Princeton , Iowa
Wow, lots of ideas. I say if you are on shore cord, use Heat Pump down to 40. You need to try it and make your own decision on cost v/s noise.
larryglarson is offline   Reply With Quote
Old 01-09-2016, 01:36 PM   #26
m.hony's Avatar
2013 30' Classic
Ditto.
Agreed.
Amen.
And what he said.
TAC #MS-10
Airforums #70955
Old 01-09-2016, 03:16 PM   #27
TCwheels's Avatar
2011 20' Flying Cloud
Traverse City , Michigan
When to use between Heatpump and Furnance
Ditto
"Don't let perfect be the enemy of better."
TCwheels is offline   Reply With Quote
Old 01-09-2016, 05:19 PM   #28
2012 28' International
Prince Edward County , Ontario
FWIW - we use two portable electric heaters (one up front, the other in the bedroom) which we set at medium. They are fine to just above freezing at which point we use the furnace.
Cyclist is offline   Reply With Quote
Virgin Roof no more. New Heatpump on my 64 with extras, tips and tricks. robwok Furnaces, Heaters, Fireplaces & Air Conditioning 14 08-28-2013 12:31 PM
New Dometic Heatpump needs help! ExcellaFella Furnaces, Heaters, Fireplaces & Air Conditioning 11 02-24-2012 07:29 AM
New Carrier A/C Heatpump Silverhobby Airstream "In the News" 1 01-27-2008 06:00 AM
Heatpump vs. Standard AC Safari Tim Furnaces, Heaters, Fireplaces & Air Conditioning 56 04-25-2007 08:32 AM
Heatpump experience Pops 2005 Safari 21 06-12-2005 11:43 AM
