Old 11-20-2019, 04:51 PM   #1
Ped
2016 23' International
Mancos , Colorado
Wheel bearings
When I had new tires installed on my 2016 FB23 I was advised that my wheel bearings were slightly loose. Where should I have these adjusted?
Ped is offline   Reply With Quote
Old 11-20-2019, 05:01 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Slightly loose was the correct adjustment on wheel bearing for many years. The installation procedure had you hand tighten the nut and then back it off until you could install a carter pin.
This was for standard bearing, I have no knowledge of the never lube bearings.
Richard
Old 11-20-2019, 06:02 PM   #3
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
If you have Never Lube bearings, there is no adjustment needed or possible.
Old 11-20-2019, 06:29 PM   #4
mkcurtiss's Avatar
1968 26' Overlander
CORDOVA , TN
As a general rule of thumb, when replacing wheel bearings, you tighten the spindle nut just until there is a little friction applied to the hub/rotor/drum, etc.....
in other words, you spin the rotor, and start tightening it very slowly...just when you see that your tension is starting to create a little friction, you stop...you then have to locate the hole in the spindle for the cotter pin, and insert the pin.....dont get it too tight, or it will overheat and create problems. Was that vague enough? ....sry, it is a procedure better watched than described.....
1968 Overlander Land Yacht International
Ford E-350 W V-10 booom!
2018 Chevy Tahoe smooooooth
Find a way to enjoy life and have fun, every day !
mkcurtiss is offline   Reply With Quote
Old 11-20-2019, 06:45 PM   #5
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
What I was taught is to tighten the nut with a wrench, back it off, then tighten it by hand. If it an opening in the castellated nut lines up with the hole in the spindle, insert the pin. If not back it off to the first opening that lines up.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 11-20-2019, 07:58 PM   #6
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
I follow Dexter procedure and tighten the nut to 50 lbs. using a torque wrench, then back it off until the wheel spins freely. this helps set the bearing.
Steamy1 is offline   Reply With Quote
Old 11-20-2019, 11:45 PM   #7
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
If you are not up for doing this yourself, any reputable RV or trailer shop can do this for you in short order.
thewarden is offline   Reply With Quote
Anyone replace MH Front Wheel Bearings? swebster Mechanics Corner - Engines, Transmission & More... 17 06-27-2004 12:55 PM
Wheel Bearings 85MH325 Axles 5 04-05-2004 07:41 AM
Wheel Bearings for a '74 Overlander AV8 Axles 5 02-03-2004 11:42 AM
repacking the Wheel Bearings Chuck Axles 26 04-27-2003 09:59 PM
Replace Wheel Bearings? Pick Axles 6 02-28-2003 07:30 PM
