Old 06-05-2015, 10:05 AM   #15
2015 25' FB Flying Cloud
Eugene , Oregon
Originally Posted by Wingeezer View Post
Good one - I have always been paranoid about that happening! Has it actually happened to you?
I would like to have some sort of a plan in mind just in case it ever does happen and I don't really know the best way to deal with it.
All I can think of is to see if one of the septic tank pumping people could remove the bulk of the black tank contents by accessing through the toilet.
I would then probably cut an access hatch in the belly pan to access and remove the defective valve - expecting that I would still have maybe 5% of the tank contents still draining out all over the place as I do that.
Not fun, but at least we only pee in the AS toilet!
Sure hope it never happens. I throw some cheap veg. cooking oil down the toilet now and then hoping it will keep the black tank valve slide lubricated and so reduce the chances of the operating rod pulling out of the slide!
Anyone have any experience in dealing with a stuck valve? I would really be interested in knowing if there any tricks and a maybe a better way to resolve the situation!
Brian.
This actually happened with our AS the first time I went to test dump (with just clean water in the tanks). I pulled the valve handle and it just kept coming! Ha! There it was in my hand connected to.....nothing!
I brought the AS to the dealer and felt silly with how simple the fix was (Uhhhhhh, I could have done that). The Service Manager used a needle-nosed pliers, reached in through the black rubber membrane cover, and pulled out the valve stem just a bit. He reattached the valve handle to the valve stem with a cotter pin, clipped the cotter pin ends, cut a small slit in the black rubber membrane to allow the cotter pin to move in and out, and voila!
Meeks is offline   Reply With Quote
Old 06-05-2015, 10:33 AM   #16
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
A little gadget that is supposed to hold the refrigerator door open during storage-
Just doesn't work-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 06-05-2015, 10:39 AM   #17
Cannonball's Avatar
2014 22' FB Sport
San Antonio , Texas
The 6' x 9' outdoor rug and two sets of lights that are supposed to hang off of the awning when it is deployed.
Cannonball is offline   Reply With Quote
Old 06-06-2015, 06:24 AM   #18
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Hmmm.
Maybe I am not clear on how these valves are made.
Also, no doubt the operating rod arrangement differs on different model trailers.
I wouldn't have a problem dealing with the situation if something in the rod linkage broke and there was something I could get hold of with pliers to open the slide.
But I am assuming what can happen is that what you call the "stem" of the valve breaks loose from the valve slide leaving nothing to get hold of to pull the slide.
Maybe if this ever happens, there might be a way to cut away part of the plastic housing on the valve (without causing a leak) just enough to grab the blade with vise grips and pull it open to drain the tank prior to unbolting the whole valve assembly.
Hope I never have to find out, but I think that is something I would be looking to try!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 06-06-2015, 08:20 AM   #19
silver 67's Avatar
1967 30' Sovereign
Leavenworth , Kansas
Chairs
Airstream chairs are overpriced on top of that they are not comfortable.
silver 67 is offline   Reply With Quote
Old 06-06-2015, 08:26 AM   #20
silver 67's Avatar
1967 30' Sovereign
The airstream chairs are overpriced and on top of that they are not comfortable. We did not buy them.
Beth and/or David
67 Sovereign, double bed, rear bath-"Moby"
2005 Dodge Ram 2500 Hemi, Quad Cab-"Ahab"
"Vintage trailer, vintage owners"
Whats the most desirable Airstream models and why? LAWFISH Off Topic Forum 48 06-06-2015 09:37 PM
Your thoughts on the most desirable Isuzusweet Classic Motorhomes 7 05-21-2013 06:05 PM
1966 Airstream Globetrotter Small VERY Desirable Campe eBay Watch Airstreams on eBay 0 05-10-2010 05:00 PM
'73 Argosy Desirable? Dieselgrin Trailer Values 8 03-31-2009 11:52 AM
Spell Check is here... At least for testing! Andy R Forum Admin, News and Member Account Info 7 06-27-2002 12:45 AM
