Old 05-02-2005, 11:44 PM   #1
Doug Stewart
das997's Avatar
2004 25' International CCD
Port Coquitlam , BC
What IS my Airstream
I was at a WBCCI rally on the weekend, and after a few hours there was a general
consensus that my A/S was one of very few exported to Europe in the early 80's.
I don't have a manual, and the serial number makes little sense (1STTBCH2XBJ500423).
It's 24'4" long, 7'4" wide, has "International" on the body, mfrd in March of 1981.
It DOES look like a miniature version of an AS when at a ralley of 35 other trailers.
The closest I've seen to the inside layout is a 1975 Argosy, but it was 8' wide vs. 7'4".
Anybody know about "International's" mfrd in 1981? The s/n has even stumped the
Airstream Company...
Thx,
Doug
das997 is offline   Reply With Quote
Old 05-03-2005, 05:54 AM   #2
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Doug, you've probably already seen this, but here is an Airstream site that helps to decypher VIN's.
http://www.airstream.com/airstream/p...e/docs/vin.pdf
Good luck,
www.nesa.org
Air No. 6427
Old 05-03-2005, 06:06 AM   #3
Old Paint, rolling again.
sfixx's Avatar
1973 Argosy 20
Lorain County , Ohio
Images: 12
Thumbs down Stranger in town
Hey Doug, What a great story...It sounds like a factory unpainted Argosy Minuet, which is said to have been built for export. Minuets are the narrower width too. Are the outside upper endcaps polished aluminum? Can you post more pictures for us?
Congradulations on having such a unique Airstream
Best wishes,
Steve
Have you never questioned those who travel? Have you paid no regard to their accounts- Job 21:29
sfixx is offline   Reply With Quote
Old 05-03-2005, 06:56 AM   #4
Images: 14
Another Airstream like this was at the Florida State Rally last Feb
Another narrow 80s (I forget the exact year) Airstream was in the vintage area at the FSR in Feb. The owner's story was that this "narrow" model was made in the Argosy factory was was part of a production run for a caravan in China at that time. They shipped the Airstreams and Suburbans to China and left them there. Several groups flew into China and used these vehicles. The owner wasn't sure how his Airstream had escaped going to or from China.
bjond is offline   Reply With Quote
Old 05-03-2005, 09:50 AM   #5
Doug Stewart
das997's Avatar
Port Coquitlam , BC
Good luck,
Hi Jim:
Here's the reply I rec'd from Airstream re: the serial number:
Hello Doug,
You have successfully stumped the factory. The serial no. that you have
given me can be divided into areas which give a story about the trailer. I
can only give you what I have here at the factory.
1ST TBCH2 X BJ500423
First Area 3 Digits means that it was manufactured by Airstream Inc.
Second Area "T" means type of trailer. Book says not used.
"B" means that it's an International.
"C" means Body Type. Book says not used.
"H" means 24' to less than 25'
"2" means Double Axle
Third Area "X" means Check Digit
Fourth Area "B" means Made in 1981
"J" means Manufactured in Jackson Center, Ohio
The rest of the six digits are the sequential production numbers assigned
to each
unit.
The wide bodies of today were not produced until 1994. Before that, bodies
were approx. 8" narrower.
The "T" and the "C" above stumps everyone here. You get the gold star of
the day.
Hope I have helped you out some.
Still confused,
Doug
Old 05-03-2005, 09:52 AM   #6
Doug Stewart
das997's Avatar
Port Coquitlam , BC
Hi Steve:
The trailer is aluminum, and was mfrd in Jackson. When I compared it to the '75 Argosy, the only similarity was the interior layout ....
I'll post a couple of photos later today...
Cheers,
Doug
Old 05-03-2005, 10:00 AM   #7
Doug Stewart
das997's Avatar
Port Coquitlam , BC
24' International Photos
Best wishes,
Steve
Hi Steve:
I think this link should get you to the photos I uploaded:
http://www.airforums.com/photo...age.php?i=8693
Cheers,
Doug
Old 05-03-2005, 10:38 AM   #8
Got gandkids?
Here’s what I get using the Airstream web info
“1 S T “ Airstream Travel Trailer
“T” Not used (possibly because it was a special production run?)
“B” Classic series trailer
“C” Semi-monocoque, 102” wide body, continuous curved, shiny aluminum shell, contoured window glass, frames and doors, galley/bedroom slideout. (That would be 8.5’ wide, did they even make slideouts in 1981?)
“H” 24’ to 25’ length
“2” Double axle
“X” Check digit
“B” 1981 model year
“J” Jackson Center manufacturing plant
“500423” Sequential production number
Weird stuff, eh?
www.nesa.org
Air No. 6427
Old 05-03-2005, 11:18 AM   #9
Thumbs up Oddity with my VIN
I just ran through the serial number for my trailer using the link posted in this thread. Everything made sense except for one thing. The 4th. position in the serial # is a "D" which according to the chart is a "Center Bath, Center Kitchen, Triple Slide". What's up with that? I have a rear bath Excella with center twins which I believe should be a "K" code. I'm using the serial # off of my insurance slip, so I thought that maybe it was a typo, and I'll have to check the trailer itself when I get home, but the weird thing is the equation for the check digit worked out correctly the way the serial # is now. If you change the 4th. digit to a "K", the check digit would be different. Has anyone here ran into something similiar? Inquiring minds want to know. P.
FYI - my serial number off of ins. slip is - 1STDEAR29BJ500217
Peter&Denise is offline   Reply With Quote
Old 05-09-2005, 09:36 AM   #10
Serial mystery
Well I finally remembered to look at the serial # on the trailer itself and the fourth digit is definitely a "D" on both serial # plates. Can anyone shed a little bit of light on this? Is the serial # chart wrong? Does anyone else with a rear-bath have a have "D' in the 4th. position in thier serial # or is it a "K"? Maybe someone was just having an off day at the Airstream factory when they assigned a serial # to my trailer. P.
Old 05-09-2005, 10:16 PM   #11
Doug Stewart
das997's Avatar
Port Coquitlam , BC
I think I'm getting closer ... found a 1980 Owners Manual for the Airstream Caravelle/Argosy Minuet. Also found a brief reference at http://www.calldon.com/air.htm regarding a short re-appearance of the Caravelle name in a 21-23' trailer in the early 80's.
I think what I have is a 1981 24' Caravelle with International badging (whatever that means).....
Old 05-10-2005, 05:29 AM   #12
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
It's just a guess, but maybe your trailer was in production when a special order, "rush" came in, and that trailer was closest to what was ordered. It had already been assigned a VIN, and that was carried through production, even though it had changed. Again, that is just a guess, but may be close to what happened.
Old 05-10-2005, 10:13 AM   #13
Good theory on the serial number discrepancy, but "Triple Slide" ? Does that refer to slide-outs? Was that even an option in '81? Not that it really matters, but it kinda makes me wonder. P.
Old 05-10-2005, 10:45 AM   #14
Well Preserved
1993 21' Sovereign
According to the "cypher", it is EITHER a Center Bath, OR a center Kitchen, OR a triple slide out, depending on year, and model. You can't have a center kitchen, and a center bath. Well, I suppose you could, but your corn flakes would get mighty soggy if you are eating breakfast, and someone else is taking a shower.
The triple slide would be for the Integrity fifth wheel.
So,... you would have a:
1- U.S. or Canada-built
ST- Airstream Trailer
D- Center Bath, or Center Kitchen
E-Excella
A-96" body, shiny aluminum
R-31-32' length
2-two axles
B-year manufactured-1981
J-check digit
500217 sequential production number
Longest Trip in a Classic AIRSTREAM Motorhome winner Airstream Motorhome Forums 17 01-26-2005 08:11 PM
... on being an Airstream Ambassador RangerJay Our Community 4 01-03-2005 08:57 PM
The Official Airstream Web Site (Airstream.com) EJWeb Link Archive 3 06-11-2002 10:50 PM
airstream! airstream! airstream! 83Excella Our Community 0 03-23-2002 10:37 PM
Airstream Related List Servers Andy R Link Archive 0 02-22-2002 02:05 PM
