Old 01-19-2013, 01:45 PM   #1
Whitehaven , Cumbria
What can a Volvo tow?
Hi all. I have been planning to get an Airstream for a few years now but now with five small children, it seems like its time. I just sold my t@b (larger one) and was looking to upgrade. I saw the flying cloud with the bunks and that got my attention. My big question is, can my Volvo xc90 tow something that big safely. I know it can physically pull one easily, but the stability part is of concern to me. The car has sway control as well as rear suspension airbags.
So in conclusion, with a proper stabilizing hitch, can I tow a 30 foot airstream, or is a smaller one in order?
Thanks!
Air Stream is offline   Reply With Quote
Old 01-19-2013, 02:08 PM   #2
kevin242's Avatar
1977 25' Tradewind
Waskesiu Lake , Saskatchewan
Send an email to Andy Thomson at Can-Am RV in Ontario, Canada. He may have already configured a vehicle like yours for towing Airstream trailers.
Kevin
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
kevin242 is offline   Reply With Quote
Old 01-19-2013, 02:15 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
The current Volvo xc90 has a tow rating of 5000 lbs and a current 30 footer weighs about 9000 to 11000 lbs. I will have to leave it to you to determine if you can safely make that combination work. Personally I would not chance it.
MICHAEL
Old 01-19-2013, 02:22 PM   #4
mutcth's Avatar
2007 23' Safari SE
Central , Connecticut
Are you doing this here or in Europe? Big difference in the trailer weights, and the UK towing regs are different.
Tom
Now: 2007 Safari SE 23' "Anne" towed by 2011 Dodge Durango "Herman"
Before: Argosy Minuet and T@B, towed by various Honda Odysseys
mutcth is offline   Reply With Quote
Old 01-19-2013, 02:29 PM   #5
Ok, that would pose a problem. I was looking on the airstream USA website but I thought it was the uk one. It seems like ours are a bit narrower.
I was reading the specs and they seemed around 6000 lbs. 10000 would be crazy.
Old 01-19-2013, 03:09 PM   #6
I moved to the uk pretty recently. All the towing numbers are confusing here.
Old 01-19-2013, 05:04 PM   #7
Road Ruler's Avatar
Images: 38
Originally Posted by kevin242 View Post
Send an email to Andy Thomson at Can-Am RV in Ontario, Canada. He may have already configured a vehicle like yours for towing Airstream trailers.Kevin
Yes.... Check in with Mr. T to see what your vehicle is good for them look for what will work.
Old 01-19-2013, 09:33 PM   #8
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
Good advise from Road Ruler. Since you are in the UK, you will have no trouble towing your desired Airstream, however, if you were in Texas, it most likely wouldn't work.
Jim Flower is offline   Reply With Quote
Old 01-19-2013, 10:10 PM   #9
2011 23' International
clovis , California
Scotty once said to Captain Kirk "I can't change the laws of physics". Are Texas and the UK that different?
jgerardi is offline   Reply With Quote
Old 01-19-2013, 10:12 PM   #10
AWCHIEF's Avatar
Images: 33
Must be something in the water.
MICHAEL
Old 01-20-2013, 01:41 AM   #11
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
When I went on the factory tour last fall, I saw the floor for a European unit. Not only are those models narrower, their assembled weight is substantially less than the models over here. The floor does not begin to equal what we get here. Nearly any small car can be seen with the strange tow knob sticking out the back. It looks like a question mark on it's side.
Old 01-20-2013, 01:45 AM   #12
RUMSHIP's Avatar
1988 32' Excella
Bonita , California
Images: 16
Is Andrew T starting a business in the UK?
Happiness only real when shared.
Christopher Johnson McCandless
2/12/68 - 8/18/92
RUMSHIP is offline   Reply With Quote
Old 01-20-2013, 03:28 AM   #13
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Yeah, that's the first thing I said too. The truth is that trailer manufacturers over here use the the 10-15% tongue weight rule & in Europe it's 5-7%. As far as overall weight of European Airstream's being significantly lower than over here, I doubt it. They do have a rather complex heating system that looks much like a hot water boiler system we use here in our houses. That must weigh more than our furnaces.
Colin
Colin H is offline   Reply With Quote
Old 01-23-2013, 01:12 AM   #14
Fly at Night's Avatar
2010 27' FB Flying Cloud
Fraser Valley , British Columbia
Two rooms of furniture from Ikea....or there abouts.
Fly at Night is offline   Reply With Quote
Old 01-23-2013, 05:40 AM   #15
jmcarter's Avatar
2010 28' International
Richmond Hill , Georgia
That's funny right there...I don't care who you are.
jmcarter is offline   Reply With Quote
