Old 11-21-2010, 07:18 PM   #1
Roadtoaster's Avatar
2015 30' Flying Cloud
Byhalia , Mississippi
We've been busy......
with projects. I posted progress pics a couple of weeks ago where we enclosed the sink and toilet area of our walk through bath. (1). Here is a pic of the final install with 3 coats of poly. (2). We wanted more drawer storage and the main closet seemed to have wasted space at the bottom so this is our cheap and light weight fix. Gives us two 6 X 26 drawers with room for the blue bag and more. (3). Our AS came from the factory with the transverse mounted queen. We immediately changed to twins but never finished the cabinet work on the street side. This version is shorter (because of the TV) and wider. The door is on order from Rockler as I don't have the correct router bits to make it. (4). The TV is on an articulating mount. I used standard door stops for stand offs and a screw down latch to keep it from moving. No straps needed. The arm is supported underneath when stowed for travel. Real important since the back of the AS bounces a bit. (5). Some friends gave us an AS birdhouse. We converted it to a lamp for the bedroom. Other projects that weren't photo worthy were the installation of a Ventline vent fan in the newly enclosed toilet area, ran a new 120 volt line to the night stand and a couple of other mods to make living more comfortable. All in all, a productive couple of weekends.
ID:	115734   Click image for larger version
ID:	115736   Click image for larger version
Greg
Roadtoaster is offline   Reply With Quote
Old 11-21-2010, 07:40 PM   #2
blmitch5's Avatar
2006 19' International CCD
Olathe , Kansas
I love the closet idea! Did you make the shell yourself? All the work you did looks great!
blmitch5 is offline   Reply With Quote
Old 11-21-2010, 07:42 PM   #3
cms4140's Avatar
Birmingham , Alabama
Looks great, Greg. Hope you all are doing well.
Chris
cms4140 is offline   Reply With Quote
Old 11-21-2010, 07:44 PM   #4
The shell is 1/2 inch ply covered with a piece of polypropylene carpet from Walmart. If you look closely you can see the ply sides through the plastic bin. I didn't see any reason to carpet the inside of each drawer cavity.
And thanks.
Greg
Old 11-21-2010, 07:45 PM   #5
Chris
Thanks Chris. All well here, hope its the same at your house. See you at the CanOpener.
Greg
Old 11-21-2010, 09:22 PM   #6
blmitch5's Avatar
Olathe , Kansas
Thumbs up
And thanks.
Thanks! I've been looking for a winter project!
Old 11-21-2010, 10:07 PM   #7
Central , Mississippi
Lookin good...finally got some good project weather here in Mississippi!
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
I bet this section stays busy... AIR-Quarius Waste Systems, Tanks & Totes 6 06-29-2010 07:15 PM
Busy - new rock shield, spare tire carrier, batteries... Mike S All Argosy Trailers 3 08-24-2008 06:50 PM
Server is busy yukionna Forum Admin, News and Member Account Info 0 05-01-2006 03:51 PM
I have been busy ! C Johnson 1965 Caravel 3 03-20-2005 01:57 PM
