Old 08-08-2003, 07:28 PM   #15
norbert's Avatar
1993 30' Excella
chicagoland , north of cheddar curtain
Images: 24
re:
thanx john...you still evaded the servel question..... i pretty much figured the inside fan would help somewhat, also the number of times you dont open de do helps.....dont you know....
and also 87...seals are important....i wouldnt run with the lp on (in which case if you did you wouldnt need the backside fan...johns reply seems to cinch...warm weather camping go with the fan...cold weather....why bother.....
norby....
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
norbert is offline   Reply With Quote
Old 08-08-2003, 08:05 PM   #16
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Re: re:
norby....
Actually, I don't know whether I ever saw a Servel.
We had ice boxes and went from them to an electric box with a great big coil on the top. I have no idea who the manufacturer was; maybe it was Servel. It held all of 3 ice cube trays, so we had to ration cubes in hot weather for our family of 5.
John W. Irwin
WBCCI #9632
Old 08-08-2003, 08:07 PM   #17
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
I have always added an exterior fan to my units. They do make a difference. I had added a large 2.4 inch CPU fan in the 76 Argosy. In the 78 I built a bracket and am intsalling 3 old computer power supply fans. Total draw about 1.25 amps. They will be right under the upper cooling fins. I should have no cooling issues with the fridge no matter the ambient temp.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 08-08-2003, 09:09 PM   #18
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I know we've discussed this before, but I'm still having a hard time picturing where exactly you are putting these fans and where they are blowing to (or on). Please try to make it obvious for me if possible I can get my hands on computer fans easy, and I'd love to have to worry about my lettuce freezing - so far that hasn't been in issue!
Stephanie
Old 08-08-2003, 09:16 PM   #19
Pahaska's Avatar
Hays County , Texas
Fans
The inside fan is one I bought from Camping World (most RV places have it). It runs on 2 D-cells that usually last me about a season. I place it on the bottom of the refringerator and make sure there is some clear space above it so the air can circulate.
If you look at the back of your refrigerator, you will see a finned radiator near the top of the back. The outside fan needs to move air through those fins. The fan can be above or below the fins, blowing upward. It doesn't need to move a whole lot of air; the refrigerator is designed to work on the thermal currents caused by the hot air rising. Any fan moves more air than the thermal currents.
My refrigerator doesn't have a roof vent, so the outside fan simply blows air out of the upper louvers.
John W. Irwin
WBCCI #9632
Old 08-08-2003, 09:22 PM   #20
Pahaska's Avatar
Hays County , Texas
By the way
I just looked at today's weather on the net. We set a new record for July ... 110 degrees at Camp mabry in Austin. Probably a couple of degrees cooler out there in the hills, but not very much cooler. My 4 tons of AC was running continuously in late afternoon.
Thanks to the rain, it is pretty nice out there at the moment.
John W. Irwin
WBCCI #9632
Old 08-08-2003, 09:26 PM   #21
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Stephanie,
Attached are pictures of the fans I built and a side view of the top back of a rv refer.
Fans
Brett G
Old 08-08-2003, 09:26 PM   #22
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Wher I designed the fans to go:
Brett G
Old 08-09-2003, 05:25 AM   #23
Pahaska's Avatar
Hays County , Texas
Originally posted by thenewkid64
Stephanie,
Fans
You should probably try either wiring the fans in series or use a dropping resistor. All that is needed is a gentle breeze across the fins; after all, they were designed to work with only thermal currents. Even a small fan breeze is many times the air movement of the intended thermal currents.
I have 4 2" fans that I bought, with giant heat sinks, for $1 each. I have been considering a similar array with pairs of the 2" fans (sans heat sinks) in series so that each fan will be running on 6V. They are absolutely silent paralleled in this way and together, move plenty of air.
John W. Irwin
WBCCI #9632
Old 08-09-2003, 07:08 AM   #24
norbert's Avatar
1993 30' Excella
Images: 24
re: fans
brett g.
most excellent design!!!
John,
my feeble old mind is having a problem comprehending your electrical design..with the fans in parallel you would need a resistor to drop the voltage to 6..would not the amp draw increase??? like kinda a mini brownout?....
norby.
Old 08-09-2003, 07:11 AM   #25
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Question
John what BTU is you AC unit? Just wondering.
Old 08-09-2003, 07:20 AM   #26
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
They are not loud now on 12 V, but when I was cannabilizing the Computer Power supplies I took them from I only had a 9 volt source. At 9 volts they were all but silent, the noisy ones got trashed.
I normally install the fans with a switch that contains a telltale to let me know they are on. I run them in the heat of the day when the refer is likley to be struggling. If they need to be run there is no way that those little fans will be heard over the noise my Armstrong AC makes
Norbert,
The thrid time is the charm, I have played with diffrent mounting systems and I decided I was going to go all out this time while I had the refer out. Much easier to work on this kind of project when you have room
Brett G
Old 08-09-2003, 07:23 AM   #27
Aluminut
2004 25' Safari
. , Illinois
Brett, that is a pretty cool design. Is your fridge unit one that vents to the top?
Eric
Old 08-09-2003, 07:30 AM   #28
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Yep,
Standard 70's style. The ivory at the top of the photo is the bottom end of the flue. I figure more air movement will increase the cooling power on those hot summer days we get here in FL. Any additional air movement helps in my experience.
Brett G
Looking for a bit of feedback ginger126 Our Community 15 02-13-2004 05:19 PM
warm outlets markus Electrical - Systems, Generators, Batteries & Solar 5 11-29-2003 04:06 PM
a bit of Wally Byam history striker Link Archive 0 03-29-2003 10:06 PM
Drill Bit Conversion Chart pap Ribs, Skins & Rivets 2 03-17-2003 09:33 PM
Tiny fan to bedroom of Sovereign helps cool and warm the space Joan D'Andrea Cabinets, Counter Tops & Furnishings 2 11-02-2002 11:10 AM
