Go Back   Airstream Forums > Airstream Community Forums > Our Community
Old 03-28-2015, 07:32 AM   #1
Sdt
2004 25' Safari
Blue Mountain , Mississippi
Weight limit of top
I weigh about 200lbs. Would a 25' 2004 Safari's top support me if I needed to get up there to do any maintenance work?
Sdt is offline   Reply With Quote
Old 03-28-2015, 08:06 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Stay on the rivet lines/ribs and you will be ok. Be extra careful around the end caps.
MICHAEL
Old 03-28-2015, 08:10 AM   #3
1974 Argosy 20
Kooskia , Idaho
You also could take an old piece of carpet and put it on a square of plywood or a board which then put carpet down on the roof to spread out your weight some.
Old 03-28-2015, 08:11 AM   #4
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
I put a painters tarp down and then use a piece of 3/4" plywood about 18" wide and long enough to span two ribs. Makes a pretty good surface to work off of.
mayco is offline   Reply With Quote
Old 03-28-2015, 08:23 AM   #5
AWCHIEF's Avatar
Images: 33
Extreme but safe and effective method,
http://www.airforums.com/forums/f44/...an-105615.html
MICHAEL
Old 03-28-2015, 08:37 AM   #6
mayco's Avatar
AWCHIEF, I dont think thats extreme at all. Safe, secure, and not that much trouble to set up. Especially if removing/replacing an ac.
Old 03-28-2015, 08:39 AM   #7
AWCHIEF's Avatar
Images: 33
Perception is everything.
MICHAEL
Old 03-28-2015, 09:03 AM   #8
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I've been up on the roof to replace my air conditioner shroud. As others noted, keep your feet on the rivet lines and you will be fine. I was about 220 at the time I did this and the trailer suffered no ill effects.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 03-28-2015, 10:27 AM   #9
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
275# and I just worked on the roof. Put 2x4 length across rivets. And it worked fine.
Hardest part is foot and hand placement when mount/dismount of roof.
I would prefer the scaffolding tho but have to rent the scaffolding. Since I can weld I am thinking of building my own specialty fit scaffold.
Peace and Blessings..
Channing
WBCCI# 30676
Old 03-28-2015, 11:17 AM   #10
HoffmanP's Avatar
2014 27' FB International
Farmville , Virginia
Do not get on the roof from either end, only the sides.
Paul Hoffman
2014 27FB International (WBCCI # 5327)
VA Plate: SOJOUNR
2013 Ford F-150 XLT Super Cab (Silver)
VA Plate: WYO2VA
HoffmanP is offline   Reply With Quote
TV Dodge Ram w/ 10,000 lb weight limit helenl Tow Vehicles 4 03-06-2013 06:18 AM
Weight limit on '65 Globetrotter REDSLED88 Axles 3 04-08-2012 09:54 PM
Weight Limit Questions gerry777 Member Introductions 3 05-04-2009 07:05 AM
B190 - Top bunk weight limit? ViewRVs Sprinter and B-van Forum 2 08-01-2007 05:53 PM
Airstream Labyrinth / Time limit on Post Composition ?? hex Forum Admin, News and Member Account Info 5 09-20-2002 02:27 PM
