Go Back   Airstream Forums > Airstream Community Forums > Our Community
Old 08-04-2003, 09:46 PM   #1
darkStar
Profile:
Weight capacities for 25' six sleepers ? (Safari/CCD)
The Airstream site lists the weight capacities of the 25' Safari six sleeper and the 25' CCD, both as 596 lbs. That seems REALLY low to me, and out of proportion with other trailers of that length, or around that length...
Does that seem right?
Thanks!
just starting to search!
darkStar is offline   Reply With Quote
Old 08-05-2003, 08:54 AM   #2
dmac
Profile:  2003 25' Safari
Eden Prairie , Minnesota
That number is wrong. I have a 2003 Safari 25 SS - I don't have ready access to the trailer right now, but the sticker on the inside of the wardrobe door tells the actual empty weight. IIRC on my heavily optioned unit the empty weight is around 4,900 lbs, and the gross weight is 6,300, for a usefull load of 1,400 lbs. From this you should subtract the weight of LP gas (~60 lbs) and water (39 gal * 7 = 273) for a net of 1,067 lbs.
Here is an old site, but with more accurate numbers than you had seen.
Dan
dmac is offline   Reply With Quote
Old 08-05-2003, 11:15 AM   #3
darkStar
Profile:
Thanks!
That seems much more reasonable! It's amazing to me that the Airstream site is so haphazard about stuff like that
Old 08-05-2003, 11:46 AM   #4
kamadeca
kamadeca's Avatar
Burlington , ON
Not to throw a damper on things, but the information on the referenced site might be dated. The picture is certainly not a 2003 Safari as it has the wooden seats (the new ones are fabric covered plastic.
Next time I am at the trailer I will check the weights.
Malcolm
kamadeca is offline   Reply With Quote
Old 08-05-2003, 12:15 PM   #5
RoadKingMoe
RoadKingMoe's Avatar
Profile:  2001 34' Limited
Beavercreek , Ohio
Here's where the cargo weight comes from:
Code:
5270 empty trailer weight (including battery(s))
+ 60 propane weight
+374 water (45 gallons including water heater)
+596 cargo weight
6300 lb GVWR
Maurice
AB8XA
WBCCI 5446
The Long, LONG Trailer
Old 08-05-2003, 12:19 PM   #6
darkStar
Profile:
Even that is great news, I was thinking the water weight would come out of the 596... wouldn't have left much for tofu and beer
weight distributing bars/trunnion bars teutonik Hitches 2 12-04-2003 07:58 AM
Dry weight variances Moonshot On The Road... 1 09-11-2003 09:06 PM
30' 70th Anniversary Edition Weight Dusty601 Towing, Tow Vehicles & Hitches 1 09-01-2003 05:33 PM
Weight Distribution, side to side JimC Towing, Tow Vehicles & Hitches 8 08-13-2003 04:19 PM
Education on Sway & Weight Distribution John Our Community 7 01-28-2003 03:48 PM
