Go Back   Airstream Forums > Airstream Community Forums > Our Community
Old 06-26-2003, 03:30 PM   #1
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 156
WBCCI Numbers on Argosy
I just removed the previous owner's WBCCI numbers from my '78 Argosy. The shadows left on an Aluminum Airstream aren't a great problem in comparison to the issues left on the Argosy. Even utilizing the least amount of heat possible, some of the underlying paint lifted (and what didn't lift turned bright yellow) with the numbers leaving more than ghosts - - I now have bright yellow numbers surrounded by the colonial white of the trailer.
In considering alternatives (the coach is to be repainted this fall), I hit upon an idea that might be workable with the Argosys. I am thinking of approaching a local sign painter about creating two magnetic signs painted Argosy off-white and appropriately sized to display the WBCCI badge and numbers. The magnetic signs could then be displayed on both endcaps (galvanized steel) whenever on the road to a Rally or Caravan as well as while at a Rally. In the off-season the magnetic signs could be stored in one of the coach's closets - - the side benefit would be preserving the numbers for multiple seasons (I have yet to get more than three seasons from a set of numbers on my Overlander).
Have any other Argosy owner's tried this approach? If so, are there any problems associated with leaving the signs attached during travel?
Kevin
Kevin D. Allen
AIR #827
Old 06-26-2003, 04:40 PM   #2
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Cool Idea!
See the galvanized ends are a benifit!
I would assume if the magnetic signs are made like the ones that people put on the side of a car they should hold just fine. The Place that makes the sign should be able to put the numbers on too in the proper height/color. Remember to leave room for your stars, or the ones that you will earn!
Brett G
WBCCI #5501 AIR # 49
Logic is the one way you can go wrong with confidence - Charles E. Kettering
Old 06-26-2003, 05:21 PM   #3
Chas's Avatar
Profile:  Austin , Texas
Images: 22
Good idea!
I am sure you can get the magnetic vinyl background in a color that would be a close match to the Argosy color. As far as I could tell my Minuet never had WBCCI numbers on it but it did have some Good Sam stickers which left very obvious traces, no paint and some rust patches. Now if there was such thing as a magnet for aluminum we would be set!
BTW, I still get to see it, my Minuet, it is sitting in the couple's driveway exactly where I delivered it, I guess they are still using it as an office
Chas
Chas is offline   Reply With Quote
HELP! applying WBCCI numbers baldeagle WBCCI Forum 33 11-15-2008 04:09 PM
WBCCI Numbers Cracker WBCCI Forum 20 09-20-2005 12:08 AM
WBCCI numbers .. identifying the owners Happycampers WBCCI Forum 7 11-11-2003 11:13 PM
WBCCI Numbers TOM CRUMP WBCCI Forum 7 10-20-2003 07:47 PM
WBCCI Numbers question? tiniree WBCCI Forum 2 04-22-2003 01:43 PM
