Go Back   Airstream Forums > Airstream Community Forums > Our Community
Old 05-02-2004, 12:56 PM   #1
gklott
gklott's Avatar
Profile:  2004 30' Classic
Johnson City , Texas
Images: 31
Water Tank Leak - broken part suggestions?
Somewhere between Las Cruces NM and home, we emptied a nearly full fresh water tank. Checking beneath, the water flows out of what appears to be a broken plastic connection. The metal guard beneath didn't protect it this time.
Picture is attached. It is curb side, behind the front wheel.
Manual page F-7 mentions the tank drain petcock. That must be what broke off.
Any commercial replacement or experience in what's involved to replace?
Any suggestions on a better, less breakable replacement?
73/gus
Gus - KR4K : Mary - K5MCL
2004 30ft. Classic dinette
2003 GMC Sierra 2500HD CrewCab/Shortbed diesel
Hensley/Prodigy
gklott is offline   Reply With Quote
Old 05-02-2004, 01:10 PM   #2
j54mark
Profile:
Surprisingly enough, that is your fresh water drain valve. They are commonly available at RV stores, are inexpensive, and not hard to replace. There should be an access panel beneath fastened by sheet metal screws.
Mark
Old 05-02-2004, 02:59 PM   #3
dscluchfc
dscluchfc's Avatar
Profile:  1984 31' Excella
Abernathy , Texas
I replaced mine in about 30 minutes. Most RV stores have them.
I had access from underneath through a door with sheet metal screws in it, and also from above from under the false floor in the closet.
Got the new valve and a short length of connection hose to make the replacemet easier...just dive in and do it, or pay $75 an hour and let a dealer do it.
dscluchfc is offline   Reply With Quote
Old 05-02-2004, 04:53 PM   #4
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
been there done that!
gklott
here is how i repaired mine, may want to take a look at your "other" drain while you are under there.
http://www.airforums.com/forum...ead.php?t=5206
john
you call them ferrets, i call them weasels.
Fresh water tank leak Flex Fresh Water Systems 3 09-30-2004 05:25 AM
New clean water tank silver suz Fresh Water Systems 19 03-29-2004 09:16 PM
fresh water tank filling system nickcrowhurst Fresh Water Systems 5 03-16-2004 01:37 PM
Water leak from Holding Tank Drain gwilliam Fresh Water Systems 4 08-02-2003 05:16 PM
Leak in hot water heater tank Rog0525 Water Heaters, Filters & Pumps 8 06-10-2002 03:10 PM
