Old 10-31-2016, 04:00 PM   #1
Bellaire , Texas
Water pump question
I have owned a 2006 25ft. safari se le for maybe 3 months. We have sold our house and are living in the trailer while we search for our new home. When I am hooked up to city water everything is fine water smells good and no bubbles. If I disconnect from city water and turn on water pump it is very loud and never seems to catch up, water pulsates. also water is very milky and bubbly. Filled and drained fresh water tank and tried again to run water pump with same results. Any suggestions would be appreciated Thanks!!
Bigeddie58 is offline   Reply With Quote
Old 10-31-2016, 04:14 PM   #2
Gearheart's Avatar
1973 Argosy 24
Kitchener , Ontario
You have song antifreeze in the fresh water system drain and flush the fresh tank a few times and try again.
Gearheart is offline   Reply With Quote
Old 10-31-2016, 04:20 PM   #3
2018 19' Flying Cloud
Newport , Washington
The noise and pulsating is normal. Like Gearheart stated, the milky bubbly appearance is probably residual RV antifreeze.
KelloggKid is offline   Reply With Quote
Old 10-31-2016, 04:21 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Sounds like you are sucking air on the intake side of the pump. Check the connections and the inline filter, it could be cracked.
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 9 08-11-2023 09:52 AM
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 10 05-25-2018 01:39 PM
Pump in RV Antifreeze Downstream from the Water Pump? KJRitchie Winterizing, Storage, Carports & Covers 6 01-09-2015 01:18 PM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
