Go Back   Airstream Forums > Airstream Community Forums > Our Community
Old 07-14-2007, 06:24 PM   #1
Kistler's Avatar
Profile:  2002 25' Classic
Oro Valley , Arizona
Water pressure regulator...from factory?
Does my trailer have an "internal" water pressure regulator? 2002 Classic--do all Airstreams have this feature?
Kistler
Brenda
Misty (Maltese)
Maxwell (grey tabby)
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
Kistler is offline   Reply With Quote
Old 07-14-2007, 06:41 PM   #2
vswingfield's Avatar
Profile:  1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Hi all,
My 67 Tradewind does for sure. I haven't noticed on the 83 Excella, just had it a few months. The one in the 67 is an ordinary hardward store item. The landlord in the park where I am located has them on every spot, just like my internal one.
Vaughan
vswingfield is online now   Reply With Quote
Old 07-14-2007, 06:59 PM   #3
Kistler's Avatar
Guess it is because of my electricity problems--needed a volt meter--and warnings about plumbing breaks, but I am becoming more aware of avoiding chance
Why does Airstream not have a voltmeter on the hood gauges...we have propane, water, batteries, holding tanks (never work)......why not a voltmeter from/for shore power?????
I would also like a water pressure reading
Kistler
Old 07-14-2007, 07:37 PM   #4
1967 24' Tradewind
Images: 32
Rivet Good Ideas
All excellent suggestions. I was just looking at volt meter this week!
Vaughan
Last edited by vswingfield; 07-14-2007 at 07:57 PM. Reason: Accidently Pasted in Previous Post
Old 07-14-2007, 07:43 PM   #5
2airishuman's Avatar
Profile:
kistler, yes your unit has a built in water pressure regulator/reducer.
you can read about it in the owners manual.
IF you want a specific in line external gauge that will read out water pressure...
camping world sells them, along with the ac volt meters...
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 07-14-2007, 08:01 PM   #6
1967 24' Tradewind
Images: 32
Rivet Thanks!
Originally Posted by 2airishuman
vaughan...
you still have time to delete or edit that misplaced post..
30 minutes or so.
cheers
2air'
Thanks 2air,
Duh, I should have noticed the “Edit” button. Cleared up now.
By the way, love your avatar. What’s the logo on your hat?
Vaughan
Old 07-14-2007, 10:29 PM   #7
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
It does but you should also be using or at least checking campground water pressure before hooking the water hose up to your trailer. I leave my adjustable regulator hooked up just in case.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
toilet doesn't hold water.... Chuck Sinks, Showers & Toilets 12 10-08-2002 11:03 AM
travelling w/out water system maznblu Fresh Water Systems 6 09-09-2002 01:03 PM
Low water pressure in Excella murf Fresh Water Systems 7 09-04-2002 08:12 AM
city water inlet valve failure? JohnGalt48 Fresh Water Systems 2 08-01-2002 05:43 PM
Flushing Black Water Tank 1985air345 General Motorhome Topics 3 05-16-2002 03:59 PM
