Old 09-11-2016, 03:12 PM   #15
1979 23' Safari
Wayland , New York
Yes it's a flow problem. Running the pump won't backfluch the inlet regulator unless it's broken. Running the pump will help determine if the regulator is the problem though. If you turn on the pump and get good water flow from your sinks then the problem is at the regulator, not the individual faucets being clogged.
The screen inlet to the regulator may be clogged. If that looks clear then 99% it's the regulator itself.
Good news is those regulator are less than $40(Amazon) and straight forward to replace.
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
High Pressure vs. Low pressure Appliances emenriquez General Appliance Topics 2 06-15-2009 01:04 AM
Tire Pressure Gauges- Pressure Varies! Ray Eklund Tires 14 07-06-2008 08:34 AM
water pressure or water pump? 59er Water Heaters, Filters & Pumps 3 07-01-2005 04:45 PM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 06:29 PM
