Old 08-18-2005, 01:15 PM   #1
Airstreamin and luvin it
Devoman's Avatar
Northwest Panhandle , The Sunshine State/WBCCI 6637
Thumbs up Water filtration system
What type of filter is very good?Should I have 2 instead of 1 to be on the safe side?Also ... Where does everyone place theres at?Need some help in deciding.Thanks.
CHANGE IS GOOD.LIFE IS GREAT!
It just cant get any better than that.
Devoman is offline   Reply With Quote
Old 08-18-2005, 03:08 PM   #2
Over59's Avatar
Putnam , Connecticut
Images: 37
Here are two sources of lots of info.
http://www.ccis.com/home/mnemeth/tech.htm
http://www.phrannie.org/
As usual there are options.
Over59 is offline   Reply With Quote
Old 08-18-2005, 03:21 PM   #3
Devo,
Here's what I did and it is terrific.
Xray's water purification scheme
If you need more info, just let me know.
67caravel is offline   Reply With Quote
Old 08-18-2005, 03:24 PM   #4
AYRSTRM2's Avatar
1966 22' Safari
1979 30' Argosy
Armada , Michigan
We just pick up a case or two of bottled, with maybe a 2.5 gallon jug to supplement. Cheaper than all the fancy systems, for as often as we camp per year.
John
AYRSTRM2 is offline   Reply With Quote
Old 08-18-2005, 03:45 PM   #5
Devoman's Avatar
Pics
Would anybody know where i could place them or should put them in a 19' Bambi Safari?Thanks.
Old 08-18-2005, 04:20 PM   #6
Can't tell you for the 19' but here's where the filter mounted in my 22' CCD.
Undersink filter install - 22' CCD
Take a look.
Good luck,
Old 08-18-2005, 04:42 PM   #7
MW64OVERLANDER's Avatar
1964 26' Overlander
Norman , Oklahoma
Images: 67
I use a 10",1 micron carbon block filter, in a single stage housing. The filter is mounted in the one stop service compartment in the rear of the trailer. This allows accessibility for changing the filter which I do once a year. It is plumbed from the outlet side of the pump and would filter all water coming from the on board storage tank.
In addition to that, I carry a second filter and housing that has been set up with a pressure regulator and hose fittings and I use this when I am using city water. This screws on at the park water faucet and your water hose connects it and the trailer. This setup protects both your hose and trailer from being over-pressured and takes the chlorine and particulates out of the park water.
Mark Wilson
1964 Overlander/2000 f250 Crew Cab 4X4 PS WBCCI# 5600
MW64OVERLANDER is offline   Reply With Quote
Old 08-18-2005, 07:48 PM   #8
Devoman's Avatar
Nice
I am liking that setup.It looks easy and out of the way.Thanks.
Old 08-04-2019, 10:45 AM   #9
Camping Dutchman
2018 33' Classic
Manchester center , Vermont
Canister water filter system; where to buy the filters?
Hi,
I have seen recommendation to build or buy a regular two canister filter system ( which I built). The two filters that are recommended are
RV-sed1 and CBCKDF. My question is where you can easily buy these filters without paying a very high shipping fee?
Menno is offline   Reply With Quote
Water problems Dbraw Fresh Water Systems 14 10-03-2009 03:15 AM
travelling w/out water system maznblu Fresh Water Systems 6 09-09-2002 01:03 PM
Water filter system 53flyingcloud Our Community 2 07-05-2002 05:43 PM
Finding water leaks FrankR Plumbing - Systems & Fixtures 0 06-27-2002 09:36 AM
Looking for ideas hot water FrankR Water Heaters, Filters & Pumps 3 05-09-2002 11:28 AM
