Old 07-31-2003, 07:34 PM   #1
1998 28' Excella
Pensacola , Florida
Question Waste Water Tanks
If an owner says their '71 27 ft has a grey water as well as a black water tank, and AS didn't come so equiped (according to what I have learned about older AS prior to 1972-3, then has a gw tank been added in some way?
jalewis is offline   Reply With Quote
Old 07-31-2003, 07:43 PM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Yep,
A 27 foot would be an Overlander. The bath is in the rear. Our 74 Overlander had a HUGE 10 gallon grey tank. If someone had tank work done then adding one at that time would have been possible. You may not have a gauge to monitor it since it was not standard equipment. I would ask what size the tanks, both black and grey are. You may need to ask a member what size black they have in the same model/year coach to see if the total gallons that can be held has increased. The biggest issue is weight. The frame in 71 was not sized for a ton of additional weight back there. If they added the grey without decreasing the black you could have a problem. Of course if you can ALLWAYS tow it with the grey tank empty the weight is not an issue.
Note: all caps=sarcasm
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 07-31-2003, 08:01 PM   #3
1998 28' Excella
Pensacola , Florida
Thanks for the quick reply. Something to keep in mind when considering an older one.
Grey water waste tanks... Chuck Waste Systems, Tanks & Totes 32 08-11-2005 06:07 AM
Combo Gray/Blk Water Tanks MaShep 1997 - 2004 Bambi 6 01-20-2004 04:24 PM
Bambi holding tanks..HEATED..CONFIRMED dtbw 1997 - 2004 Bambi 3 06-30-2003 06:47 AM
Retrofit Grey water tanks smily Waste Systems, Tanks & Totes 10 02-01-2003 12:17 AM
Waste Water Outlet Valves Danno Waste Systems, Tanks & Totes 2 06-18-2002 10:48 AM
