Go Back   Airstream Forums > Airstream Community Forums > Our Community
Old 03-08-2003, 03:08 PM   #1
Kistler
Kistler's Avatar
Profile:  2002 25' Classic
Oro Valley , Arizona
Walbernized the rock guards and...
The rock guards didn't come out like the trailer body--shining?? Did someone once post that the rock guards should not be Walbernized?
Apparently the rock guards are not coated the same as the trailer body.
What should I do to return them to the shape they were in? They are blotchey.
Kistler
Brenda
Misty (Maltese)
Maxwell (grey tabby)
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
Kistler is offline   Reply With Quote
Old 03-08-2003, 05:18 PM   #2
jcanavera
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
You can do them but the finish on the guards is different and doesn't take the Walbernize like the trailer body does. It takes some elbow grease and you need to lay the Walbernize on several times. You can get them looking pretty good this way. If you just do the single coat the guards come out sort of splotchy looking.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
jcanavera is online now   Reply With Quote
Old 03-08-2003, 06:59 PM   #3
Kistler
Kistler's Avatar
Thank you for the reply, Jack. I guess that I'll leave the splotchey look and hope it wears away with time and washing.
I have another question regarding Walbernizing, cleaning and washing concerning the roof. How do you get onto the roof?
I have a "ladder system" which is sort of an adjustable step ladder. I can get to roof level but with the shape of the coach, I am about 2 feet away from the roof. If I lean over I can grab a hold on the awning and climb on but that is a little un nerving.
If I lean the ladder (make it straight like an extension ladder) I am afraid I will dent the coach. Any ideas?
Kistler
Old 03-08-2003, 09:05 PM   #4
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Kistler
If the ladder is tall enough you could lean it on the awning rollers. If not you may want to fashion a cross piece with a 2X4 that is wide enough to span the ribs , cover it with a soft cover, Carpet covered with an old towel works great, and lash it to the top of the ladder. This will spread the weight of you and the ladder over 2 or more ribs and keep you from denting your new unit.
Hope this helps
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 03-08-2003, 11:52 PM   #5
jcanavera
jcanavera's Avatar
Fenton , Missouri
Images: 143
Kistler
I bought an extendable pole with a large soft brush end at Camping World that I use to wash the roof (and the rest of the trailer). I have an extension A frame ladder that is almost as tall as the trailer. I keep a bucket on the ground that contains my Armor-All water mixture. I have the pole extended and I can dip the brush into the bucket and then raise it to the roof. Roof cleans up great this way.
As far as getting on the roof. I haven't tried to yet. I can Walbernize the entire trailer except the painted white roof. Can't reach that without getting up there. I've put this off so far but I probably will need to do eventually. I should pull the cover off the Penguin to make sure it is clean and the drain is clear of windblown debris.
I've seen methods from placing a ladder against the awing roller and going up that way, to making a small platform which can traverse the distance from the roof to an A frame ladder. None look great to one who doesn't like heights.
Jack
Jack Canavera
STL Mo.
AIR #56
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 03-09-2003, 08:16 AM   #6
lynn
lynn's Avatar
Profile:
The wrap protectors are stainless steel and not aluminum. They do not have a coating on them. The splotches are from the Walbernize getting in the grain of the metal. Alcohol should remove the Walbernize.
lynn is offline   Reply With Quote
Old 03-09-2003, 09:14 AM   #7
Kistler
Kistler's Avatar
Thank you all for your advice; and Lynn, do you mean plain old rubbing alcohol?
Covered 2 X 4 across ribs sounds good to me. I noticed that the end caps really can't support much; I leaned on one and it gave like there is nothing underneath. I think John mentioned when walking on the roof to stay off the end caps.
Kistler
Old 03-09-2003, 09:17 AM   #8
thenewkid64
Just a member
Images: 21
The rivet lines in the end caps are standing seams that usally have no support underneath. There should be a horizontal rib across the top of the rear window, but I would try to reach the end/top from the side to avoid possible damage.
Brett G
Old 03-09-2003, 09:56 AM   #9
wb13798
wb13798's Avatar
Profile:  2004 28' Classic
huntsville , Alabama
you are correct the end caps dont have very much support under them . best stay off . the painted top i would use a wash that has a wax in it . and also stay off the top. if you dont have to go up dont. to clean the ac drain hose that is accomplished from the inside. if it aint broke dont fix it. lol
al
wb13798 is offline   Reply With Quote
Old 03-09-2003, 01:30 PM   #10
Kistler
Kistler's Avatar
Have I told you lately that I appreciate you--all of you. I purchased a "wand" type washing brush and I think I'll stay off the roof.
I can imagine what it would cost for bodywork, especially on top or at the ends.
Kistler
Brenda
Misty (Maltese)
2002 Classic 25'
Old 03-09-2003, 04:05 PM   #11
jcanavera
jcanavera's Avatar
Fenton , Missouri
Images: 143
al
I would assume that the pan can collect windblown debris. Wouldn't that debris eventually clog the the drain in the pan?
Jack
Jack Canavera
STL Mo.
AIR #56
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 03-09-2003, 04:48 PM   #12
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Hey, while on the subject of the guards, seeing that they are stainless vs. aluminum, are they less prone to dents from stuff flying off the rear of the car?
Eric
Old 03-10-2003, 08:12 AM   #13
jcanavera
jcanavera's Avatar
Fenton , Missouri
Images: 143
Yes, they can take a little more impact. I do have some small dents on mine so they are doing their job.
Jack
Jack Canavera
STL Mo.
AIR #56
'03 GMC Savana 2500
'08 Vespa GTS 250
How to modify and install rock guard on minuet Janet All Argosy Trailers 42 09-29-2008 07:54 PM
swap rock guards bill benton Parts Archive 4 03-25-2004 08:21 PM
Minuet Front Window Rock Guards overlander64 All Argosy Trailers 54 12-01-2003 10:13 PM
rock guards segment protectors joecj76 Rock Guards, Segment & Window Protectors 21 07-02-2003 11:54 AM
