Old 03-14-2004, 06:50 AM   #1
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Walbernize on Tow Vehicle?
I purchased some from the local dealer, and asked if this could be used on my GMC pickup. They said, "Sure, no problem!". Anyone else tried using this stuff on a clearcoated vehicle?
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 03-14-2004, 07:40 AM   #2
baldeagle's Avatar
worked just fine on my suburban....
baldeagle is offline   Reply With Quote
Old 03-14-2004, 07:48 AM   #3
cosmotini's Avatar
1963 24' Tradewind
Highland , Illinois
Images: 83
www.walbernize.com
The web site says it's safe on all finishes. It would be nice not to have duplicate products for the same job.
Dennis
cosmotini is offline   Reply With Quote
Old 03-14-2004, 09:46 PM   #4
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
worked fine on my z71 pick up and the trail blazer. it is a paint sealer. i used a simonize wax and sealer up till now on the airstream and vehicles. decided to use walbernizer in the qt bottles it is about the same price as the simonize. i got my supply from airstream dreams. http://www.airstreamdreams.com/ it was a bit cheaper than other sources, plus shipping isn't more than the walbernizer.
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 WB , Pro Pride P-3 hitch
centramatics wheel ballancers 300-556
wb13798 is offline   Reply With Quote
Old 03-18-2004, 06:59 PM   #5
doh
doh's Avatar
1999 25' Safari
Manchaca , Texas
Thumbs up The Pink Stuff
I had a old 1992 Dodge van (white) with some serious dark stains on the door outside - nothing would remove the 'stains in the paint' - but Walbernize made them go away almost instantly - it was rather amazing and very surprising. Good Stuff.
Does not work real good on the Airstreams SS rock guards, gets splotchy - it seems that the best thing for them is just soap and water.
doh is offline   Reply With Quote
Old 03-18-2004, 10:48 PM   #6
North Central , USA
OK, I'll bite...; What is or what is so special about walbernize? Isn't wax, wax??
RivetED is offline   Reply With Quote
Old 03-19-2004, 05:20 AM   #7
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
Images: 36
Oh no, it's not JUST a wax. It's a cleaner. It's a polisher. It's a sealer. It's SUPER PINK STUFF!!
ARS WA8ZYT
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 03-19-2004, 06:56 AM   #8
baldeagle's Avatar
Timely Tip
Thanks for the comment on the SS Rock Guards. I was ready to Walbernize mine for the first time today.
Guess is will just keep after them with soap and water.
Dave S.
Old 03-19-2004, 05:59 PM   #9
doh
doh's Avatar
1999 25' Safari
Manchaca , Texas
Polishing Rock Guards
Perhaps it's just mine but
After the pink stiff - I tried some metal polish - specifically for SS, same thing - rag turned black quickly, same splotchy look.
Has been several months now and they look good again - I suspect there is a lot of something on top of the SS & eventually I'd get a uniform appearance with no black residue on the rag - but it just ain't worth the effort.
I'd rather apply that level of effort to the trailer where there something to protect. SS will take care of itself.
Old 03-19-2004, 06:25 PM   #10
"Stainless" steel is only "stainless" because it is covered with a very fine film of "rust" after exposure to air. This virtually invisible layer protects the steel from further oxidation. Polishing with any abrasive polish just disturbs this layer, exposing the underlying metal, and the oxide has to re-form over time. That's why soap and water is best, as suggested above. It does not disturb the protective coating of oxide.This is particularly relevant on ocean-going yachts. Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 03-19-2004, 06:27 PM   #11
North Central , USA
Is this available at "most auto parts" stores; ie: Pep Boys?
Old 03-19-2004, 07:37 PM   #12
doh
doh's Avatar
1999 25' Safari
Manchaca , Texas
Pep Boy's?
I don't think so,.... but who knows
You can always go to your favorite Internet search engine and take a peek at the WWW.
Should be available at your friendly local Airstream dealer, or Airstream.com store and other places such as the Walbernize.com site. List price is about $13.00 / Qt - you typically see it for about $16.25 / Qt "RV Super Seal".
I'd either buy it at my dealer - or Walbernize.com (& pay the shipping)
The following is from the Walbernize home page:
Walbernize is committed to excellence in RV Care Products.
We have manufactured Waxes, Polishes, Sealers, and Cleaners for the RV industry since 1968. Our company offers products for any RV with a special emphasis on Airstream Coaches.
Old 03-19-2004, 07:58 PM   #13
doh
doh's Avatar
1999 25' Safari
Manchaca , Texas
nickcrowhurst
Stainless is Stainless because it has a high nickel content, which is why stainless is so 'hard' and expensive to machine. Good stainless steel will never rust, cheap stainless steel (low nickel content) will rust. The magnet test always works.
However - everything else you said 'computes' - the black stuff coming off seemed to be oxidation, and a uniform appearance eventually returned.
Old 03-19-2004, 08:28 PM   #14
Doh, http://en.wikipedia.org/wiki/Stainless_steel states:-
Stainless steel
From Wikipedia, the free encyclopedia.
In metallurgy, stainless steel is defined[1] as a ferrous alloy with a minimum of 10.5% chromium content. Such steels have higher resistance to oxidation (rust) and corrosion in several environments. It was invented in 1912, at the research laboratory of Brown-Firth, Sheffield, England by Harry Brearley. He had been investigating ways to reduce corrosion in gun-barrels, when it was noticed that a discarded sample was not rusting.
High oxidation resistance in air at ambient temperature is normally achieved with additions of more than 12%(weight) chromium. The chromium forms a layer of chromium (III) oxide (Cr2O3) when exposed to oxygen. The layer is too thin to be visible, meaning the metal stays shiny. It is, however, impervious to water and air, protecting the metal beneath. Also, when the surface is scratched this layer quickly reforms.
References
[1] AISI (American Iron and Steel Institute)
[2] ISO 3506 standard
Other metals are added,to produce particular types of stainless steel, of course.
Nick.
