Old 08-14-2018, 09:43 PM   #1
1980 25' International
Napanee , Ontario
Vinyl stripe removal
My 1980 vinyl pinstripes are dull, cracked, dried out. It cannot be peeled off. Does anyone have a good solution on how this can be removed?
Richard1950 is offline   Reply With Quote
Old 08-14-2018, 09:59 PM   #2
2018 25' Flying Cloud
Marana , Arizona
Get a heat gun, set it on low, make sure you have seating that has casters and take it inch by inch.
Zardoz is offline   Reply With Quote
Old 08-14-2018, 10:00 PM   #3
Wrangler's Avatar
2019 19' Flying Cloud
Renville , Minnesota
I use a heat gun and wood spatula. Start with the heat gun on low heat setting.
I currently camp in a 19’ Flying Cloud towed by a Nissan Frontier.
Wrangler is offline   Reply With Quote
Old 08-14-2018, 10:01 PM   #4
Napanee , Ontario
I tried a heat gun. No luck. It seems to be "baked" on the surface.
Old 08-14-2018, 10:22 PM   #5
Wrangler's Avatar
If a heat gun does not work, try working an oil under the vinyl. Spray with WD40 or rub vigorously with peanut butter. The oil will soften the baked on adhesive and allow the vinyl to separate from the trailer skin. A heat gun did the trick for me when I removed the decals from my old Scamp.
Old 08-14-2018, 11:21 PM   #6
2007 22' International CCD
Try “Rapid Remover” from Amazon. Used in the vinyl sign industry to remove old vinyl and adhesive.
Old 08-15-2018, 01:04 AM   #7
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I did mine with paint stripper. The hardest job I have done on the trailer, I think. It took 3 applications of stripper waiting just the right time between application and scraping with a plastic spatula. When it comes off it leaves shadows of the stripe pattern in the Al. But the trailer looks a lot better without it. I used Citri strip at first but thr stripper I bought At Woodcraft worked slightly better.
I spent days trying different solvents and heat sources but the only thing I found that worked was the paint stripper. And yes you have to tape the stripe off and keep the stripper from running down the side on the clear coat below the stripe.
Old 08-15-2018, 06:21 AM   #8
Napanee , Ontario
Thanks for the suggestions. I will give anything and everything a try.
Blue Center Stripe - Vinyl Roll Approx 7" Wide x 125 Long AngeloC Airstream Classifieds 0 05-01-2018 04:03 PM
Under Vinyl stripe, white stain removal? brianbraun Cleaning, Stripping & Polishing 0 03-20-2013 12:36 PM
Vinyl Stripe Removal and Replacement dbj216 Clearcoat, Exterior Paint & Trim 2 06-08-2012 05:21 AM
Help Removing Vinyl Stripe dbj216 Clearcoat, Exterior Paint & Trim 6 07-23-2010 06:50 PM
Vinyl stripe painting pacer General Repair Forum 5 06-18-2009 02:22 PM
