Old 05-12-2019, 05:57 PM   #1
1958 22' Flying Cloud
Shalimar , Florida
vintage airstream shell restore only
1958 22' flying cloud, I have been wanting to do this for years. I bought this for me and my wife and dog. I bought an eastwood drum polisher and a few hundred dollars of nuvite. I can't get these black pitted marks out. I don't mind the pits but can't live with the black splochtes. I can buy new aluminum wholesale but the end caps are way too much. any one have a suggestion on how to get the black out? I want to do the outside in original but the inside all brand new. My wife will clamp but not camp. and how do you post pics here? Thanks.
Willsmth3 is offline   Reply With Quote
Old 05-12-2019, 06:48 PM   #2
PA BAMBI II's Avatar
1964 17' Bambi II
Strasburg , Pennsylvania
lacquer thinner
The by-product of polishing is the black residue of aluminum oxidation. You need to spray and wipe down each just-polished section of aluminum with lacquer thinner to remove the black residue. It will come up looking pretty good at that point.
"The difference between vintage and retro is that vintage is honestly old and cool. Retro tries to be but isn't."
PA BAMBI II is offline   Reply With Quote
Old 05-12-2019, 07:49 PM   #3
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 21
Before you use thinner I would suggest trying some regular flour on a towel. It will pick up most of the black residue. Also you may find lacquer thinner leaves a cloudy look. Some recommend mineral spirits instead. Use your choice to clean up any heavy stubborn spots.
To post a picture, when you start the reply/post, go up to the tool bar and click the paper clip. A same window will open that allows you to choose up to 4 pics. Be aware there is a size limitation. I believe its 500 KB. I find that using Paint to resize the pic to that limit is easy do. Paint will also allow you to rotate, add lines, circle something, etc..
Look at the size of your original pic. i.e. 1.0MB
Open pic in Paint
Click on resize. Change 100% to what ever divides original down to 500KB i.e. 50%
Save as jpg .
Double check size of reduced pic when saved, and adjust again if needed.
When you've chosen all the pics to download, hit the download button in the small window and wait.
When its done, go back to your thread to continue.
Click the paper clip at the place you want to insert photo and choose from the list in the window.
Hope this helps.
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Shell off restore, need interior light rec racecannon Lights - Interior & Exterior 5 03-19-2016 01:34 PM
2014 airstream shell - 25' international - blank shell released from airstream!! LaraW Airstream Classifieds 0 08-25-2014 01:32 PM
HELP! Can I fix sagging Outriggers with shell on? Or just pull the shell? Mixter Repairing/Replacing Floor &/or Frame 3 01-24-2013 11:59 AM
Shell on? Shell off? Althea68 Repairing/Replacing Floor &/or Frame 55 04-01-2011 09:35 PM
Shell Off vs Shell On Summary mbatm01 Repairing/Replacing Floor &/or Frame 82 01-09-2006 05:46 PM
