07-05-2015, 06:03 AM
#21
Biloxi
, Mississippi
The repeater install could not be simpler. I put it in my battery box using double sided tape. Two wires, one to ground and one to positive terminal. I used a marine two terminal quick disconnect plug that I already had installed for accessory hookups. ie: 12 volt plug, meter, air compressor, etc.
MICHAEL
07-05-2015, 07:26 AM
#22
2016 28' Flying Cloud
Brandenburg
, Kentucky
Sure would like to see photos of your 12v connection.
07-05-2015, 07:29 AM
#23
Brandenburg
, Kentucky
Well darn it
Originally Posted by mbenson1234
Tsunami, yes we are having a discount for the holiday weekend. Call me I'm here til midnight @770-889-9102
Mike Benson
TST
Just checked into the forum to find your post. Spent the evening at Fort Knox Kentucky celebrating 4th of July with some of the Soldiers and civilians that used to work for me prior to my retirement from civil service. Any possibility to extend the offer? Thanks
07-05-2015, 09:02 AM
#24
Biloxi
, Mississippi
Crappy picture but best I can do. It is very tight space. Plug is in center of photo. Repeater is the orang dot. It is mounted to the inside of front wall of box using double sided tape. Negative goes to common ground and positive to positive terminal of battery. Water on battery is rain.
MICHAEL
07-05-2015, 09:30 AM
#25
2011 30' Classic
2007 25' International CCD
1993 32' Excella
Largo
Originally Posted by ghaynes755
Carver still no video
OK, when all else fails we will go to the picture attachments. I wish I knew what went wrong with the video.
>>ron<<
2015 GMC Denali 2500, 4x4, Duramax diesel, Topper, Pro Pride 3 P, Sendel 16" with Michelin LTs, one Yellow Labrador Retriever (AS security)
07-05-2015, 10:38 AM
#26
2010 28' Flying Cloud
Lower Alabama
, USA
Looks like a significant number of the installs require the repeater. If you were buying the system should you go ahead and buy it with the repeater included in the package?
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
07-05-2015, 10:58 AM
#27
Biloxi
, Mississippi
I would wait and see if it is necessary.
MICHAEL
07-05-2015, 02:49 PM
#28
2012 27' Flying Cloud
W
, New England
Tst tpms
I thought I was going to need it after I installed my Voyager camera. Some weird interference. But moving the TST to the driver's window resolved that problem. Mine is a 27' with extended cab truck (50' total length).
I would agree with AWCHIEF - don't buy it unless you need it.
07-05-2015, 06:28 PM
#29
Lower Alabama
, USA
Michael has a 23' trailer and he needed it plus others have posted how they mounted it. So looks like a strong chance that it will be necessary.
Alan
Air #64439
07-05-2015, 07:57 PM
#30
1999 34' Excella
Hillsboro
Running down 2 lane highways... I get good signal on all 3 axles... on Interstate or other times where cars are on the side of me for a long time, I tend to lose signal.
Geez.. it's only a 34'!!!
Ok, so, I get a 'repeater'... I mounted it near my rear bumper of the TV.. tied it into the 'running lights' of the TV.. So, all I do is turn on the headlights when towing (something I always tended to do anyway)... and the 'repeater' only runs some times..
Workie fine...
Peace and Blessings..
Channing
WBCCI# 30676
07-05-2015, 08:12 PM
#31
2013 28' Flying Cloud
Central
, Canada
Tst tpms
If I may, I would like to also compliment Mike on their wonderful customer service and product.... Stellar !
For those wondering about the repeaters. I purchased one with the system and installed it in my battery box. I also put a simple inline switch to allow be to turn it off and on when I wanted..... (IE-storage)
In the end I don't use mine as my signal is strong enough without it. (28' and an F150)
That said, I'm still glad I got it as my reception might change down the road and if it does all I need to do is turn it on.
Thanks again Mike
Cheers
Doug
Trying to use my camera to create memories - not photographs!
