Old 07-04-2015, 06:42 AM   #15
Cumming , Georgia
Excellent!!
mbenson1234 is offline   Reply With Quote
Old 07-04-2015, 06:44 AM   #16
Cumming , Georgia
Tsunami, yes we are having a discount for the holiday weekend. Call me I'm here til midnight @770-889-9102
Mike Benson
TST
Old 07-04-2015, 12:26 PM   #17
carver 1's Avatar
2011 30' Classic
2007 25' International CCD
1993 32' Excella
Largo , Florida
Images: 30
Repeater installation
For those of us who have to install a repeater. I was loosing the signal every now and then when a truck passed me on the left. Mike suggested the use of a repeater since i have a 30' AS and a long toad with the monitor mounted on the dash. The attached video shows what I did and since, there has been on interruption of signal.
>>ron<<
2015 GMC Denali 2500, 4x4, Duramax diesel, Topper, Pro Pride 3 P, Sendel 16" with Michelin LTs, one Yellow Labrador Retriever (AS security)
carver 1 is offline   Reply With Quote
Old 07-04-2015, 12:40 PM   #18
Hiho Silver's Avatar
2016 27' Flying Cloud
Overland Park , Kansas
Hiho Silver is offline   Reply With Quote
Old 07-04-2015, 12:48 PM   #19
carver 1's Avatar
2011 30' Classic
1993 32' Excella
Largo , Florida
Images: 30
Whoops. Here's the video
>>ron<<
Old 07-04-2015, 05:02 PM   #20
2016 30' Classic
Erie , Colorado
Carver still no video
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 07-05-2015, 06:03 AM   #21
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
The repeater install could not be simpler. I put it in my battery box using double sided tape. Two wires, one to ground and one to positive terminal. I used a marine two terminal quick disconnect plug that I already had installed for accessory hookups. ie: 12 volt plug, meter, air compressor, etc.
MICHAEL
Old 07-05-2015, 07:26 AM   #22
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
Sure would like to see photos of your 12v connection.
tsunami is offline   Reply With Quote
Old 07-05-2015, 07:29 AM   #23
tsunami's Avatar
Images: 20
Well darn it
Mike Benson
TST
Just checked into the forum to find your post. Spent the evening at Fort Knox Kentucky celebrating 4th of July with some of the Soldiers and civilians that used to work for me prior to my retirement from civil service. Any possibility to extend the offer? Thanks
Old 07-05-2015, 09:02 AM   #24
AWCHIEF's Avatar
Images: 33
Crappy picture but best I can do. It is very tight space. Plug is in center of photo. Repeater is the orang dot. It is mounted to the inside of front wall of box using double sided tape. Negative goes to common ground and positive to positive terminal of battery. Water on battery is rain.
MICHAEL
Old 07-05-2015, 09:30 AM   #25
carver 1's Avatar
2011 30' Classic
1993 32' Excella
Largo , Florida
Images: 30
OK, when all else fails we will go to the picture attachments. I wish I knew what went wrong with the video.
>>ron<<
Name:	repeater location (1).jpg
ID:	242229   Click image for larger version
Old 07-05-2015, 10:38 AM   #26
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Looks like a significant number of the installs require the repeater. If you were buying the system should you go ahead and buy it with the repeater included in the package?
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
Old 07-05-2015, 10:58 AM   #27
AWCHIEF's Avatar
Images: 33
I would wait and see if it is necessary.
MICHAEL
Old 07-05-2015, 02:49 PM   #28
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Tst tpms
I thought I was going to need it after I installed my Voyager camera. Some weird interference. But moving the TST to the driver's window resolved that problem. Mine is a 27' with extended cab truck (50' total length).
I would agree with AWCHIEF - don't buy it unless you need it.
Tire Minder or TST TPMS for 30' FC Beach Bum Tires 8 02-05-2015 12:25 AM
Voyager interferes with TST TPMS SteveSueMac Lights - Interior & Exterior 11 12-09-2014 08:03 AM
Tst tpms SilverEagle6 Tires 6 08-09-2014 06:22 AM
TST TPMS fit and repeater SteveSueMac Tires 6 08-17-2013 12:29 PM
Valve stems and TPMS cosmotini Wheels, Hubs & Bearings 8 08-06-2013 07:28 PM
