Old 03-24-2007, 10:42 AM   #15
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
That's an excellent poster! I chuckled out loud as I looked at it. We're really fortunate here that very, VERY infrequently do we actually see a troll. The vast majority of our members are just looking for other Airstream owners with which to exchange info and hang out. Occasionally members will really be passionate about one topic or another, but that's really ok. After all, when we meet at rallies we have those same discussions, and folks are folks. Many times those discussions can be educational as well.
Roger
Old 03-24-2007, 11:55 AM   #16
Waynon's Avatar
1986 34' Excella
You said it, Boatdoc!
Originally Posted by boatdoc
...Our posts only express different views on particular problem. If you combine them and research the possibilities presented to you, perhaps than in your own mind you may find one that may fit your level of fix. someones knowledge and experience....
.... but we cannot turn the forums into a battle zone of witt's as it has been done at times in the past. We must remember that it is possible that that someone else may know more than we do or understand, and criticism based only on difference of opinion is not a viable option. Thanks, "Boatdoc"
Wish I could have said it so well! He does bring up a really good and scary point. I think his example of someone checking for propane leaks is priceless. In a case like that I would think that everyone would agree that the poster needs to be alerted.
It's all about attitude and method. Even in the obvious dangerous situation like that, I hope none of us would come out with the tempting, "Hey, you idiot..."
Like the poster above said about doing unto others...
Waynon
Waynon is offline   Reply With Quote
Old 03-25-2007, 11:49 AM   #17
Pop Rivet's Avatar
1990 25' Airstream 250
Altoona , Georgia
Cool
I think this is what I gather from the responses.
1. If it is not a safety issue or something that could result in equipment failure. don't worry about correcting folks, Certainly not worth making folks mad.
2. If it is a safety issue or could cause equipment damage, Approach the issue diplomatically.
Pop Rivet is offline   Reply With Quote
Old 03-26-2007, 06:03 AM   #18
boatdoc's Avatar
1973 Argosy 26
Norristown , Pennsylvania
Originally Posted by Jim Clark
Disagree and wrong are two different statments. A fact which is presented as correct and is wrong can get you hurt. Example weight of a trailer, capacity of a TV, using a match to find a propane leak. Disagree on what type of hitch to use, which truck is better, that is just personal and can never be resolved. I would correct wrong statements which are safety issues with facts and backup information, the disagreements can be discussed until you can't take it anymore.
Thanks Jim
Hi Jim: I wholeheartedly agree with you, but I did not think that there would be individuals this days who would try to find a gas leak with a match or tow a 31' trailer with a donkey. Thanks, "Boatdoc"
boatdoc is offline   Reply With Quote
Old 03-26-2007, 06:17 AM   #19
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
There is a new member here on the forums that recently towed a Sovereign from Alabama to Pennsylvania with a Ford Ranger. Just an example, and proof of what we are discussing.
Old 03-26-2007, 06:26 AM   #20
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
.......... but I did not think that there would be individuals this days who would try to find a gas leak with a match ........
Man, what kind of dolt would do that? Everyone knows a candle is better for that. A candle gives you more reach and wont burn out as easily. Some people, really!
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 03-26-2007, 07:17 AM   #21
85MH325's Avatar
Tipton , Iowa
Images: 37
Rodney, what a GREAT idea! I was using my propane torch, but I couldn't tell which flame was from the propane line and which was from the torch when I hit the leak. I'll be that a candle would show the propane leak much better! Thanks!
Roger
Old 03-26-2007, 07:38 AM   #22
Images: 59
You guys are gonna kill someone.
Before you do a leak test you need to "burn-in" the tubing to anneal it. Wrap the tubing in cloth strips, then soak with gasoline and light with a Zippo.
Voila!
Old 03-26-2007, 07:43 AM   #23
85MH325's Avatar
Tipton , Iowa
Images: 37
Voila!
That sounds dangerous. Isn't that something they do at the factory? I think Scamp Trailers in Backus, MN did it that way for a while.
Roger
Old 03-26-2007, 08:28 AM   #24
Images: 59
Roger
I was reading that just yesterday, when someone mentioned bringing back the Argosy, in fiberglass. The plant is back in operation after their dreadful fire.
Old 03-26-2007, 08:35 AM   #25
Moonstruck's Avatar
1986 31' Sovereign
1975 25' Tradewind
1967 17' Caravel
Sherfield English , Hampshire
Send a message via MSN to Moonstruck Send a message via Yahoo to Moonstruck
Leak test or Darwin test?
May I suggest you do what my gas fitter always does. Before you turn the gas back on, get your bottle of thick, gloopy washing-up liquid and pour liberally over the connections. If even a tiny amount of gas escapes from the threads etc. bubbles will form all over the joint.
Marc
Silvertwinkie
Hampshire, UK
Moonstruck is offline   Reply With Quote
Old 03-26-2007, 08:52 AM   #26
85MH325's Avatar
Tipton , Iowa
Images: 37
As a former owner of three Scamps over the years, the 13', the 16' AND a 19' fifth wheel, I was really pleased to see them back in operation so quickly. I've heard that their new plant is quite the operation.
Marc
Marc, did you just flame me?
Roger
Old 03-26-2007, 08:59 AM   #27
Moonstruck's Avatar
1986 31' Sovereign
1975 25' Tradewind
1967 17' Caravel
Roger
No, No! You don't need any help with that!
Silvertwinkie
Hampshire, UK
Old 03-26-2007, 03:29 PM   #28
boatdoc's Avatar
1973 Argosy 26
Voila!
Hi Mark; You guys are terrible, picking on God's special people. "Boatdoc"
Blue Beret Discouraged Big Dee WBCCI Forum 84 03-19-2006 04:09 PM
Security luckydc Our Community 26 06-06-2004 02:50 PM
The naked truth Rog0525 Our Community 14 03-08-2004 05:58 PM
please be truthful striker 1965 - 1969 Overlander 20 02-07-2004 09:29 PM
Consequences of overloaded tow vehicle? ipso_facto Tow Vehicles 12 06-29-2003 11:50 AM
