Old 05-23-2015, 12:53 PM   #1
1965 22' Safari
chicago , Illinois
Trouble with pump getting water to sink
I have water filled in fresh water tank, have city water hooked up. When I drain the hot and cold pump stays on. Close valves pump goes off. Any help would be nice, can't get water to kitchen sink.
kevin1975 is offline   Reply With Quote
Old 05-23-2015, 01:14 PM   #2
richw46's Avatar
Lexington , Kentucky
Have you checked the aerator on the kitchen faucet? They clog easily.
Do you have water at the bathroom sink? Toilet?
If you are hooked up to city water you shouldn't have the pump turned on. If your water tank is full, disconnect city water hookup, turn on the pump. Once the pressure equalizes in the pipes the pump will stop until you open a faucet. The pump will keep pumping until the faucet is closed and the pressure equalizes again.
If you hook up to city water, turn the pump off (it may disable anyway because of the city water pressure.) Try all the faucets, cold first, to see if you get water out.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 05-23-2015, 03:35 PM   #3
1965 22' Safari
chicago , Illinois
Thanks, 1965 Safari, it was another leak next to fridge and sink faucet was clogged.
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 06:46 PM
Any trouble getting Chrysler corp. parts? 63air Off Topic Forum 21 06-23-2009 09:12 PM
Trouble debugging my water pump Simoneau Water Heaters, Filters & Pumps 2 08-06-2008 12:10 PM
One sink, two sinks, red sink, blue sink? Janet H General Interior Topics 7 07-26-2006 06:17 PM
Trouble Getting Logged on Mike Lewis Forum Admin, News and Member Account Info 16 02-06-2005 10:46 AM
