Old 03-30-2004, 03:22 PM   #15
stuart2's Avatar
Aw! What a shame to waste a good source of fuel. What about an inline pressure reducer to bring the PSI down to something more managable?
stuart2 is offline   Reply With Quote
Old 03-30-2004, 03:32 PM   #16
2004 19' Bambi
Denver , Colorado
Images: 32
... and you thought GAS was getting expensive? Take a look at this pricey little gas can ...
http://automotive.aubuchonhardware.c...can-574325.asp
Go Figure
COLORADO_CAMPER is offline   Reply With Quote
Old 03-30-2004, 03:33 PM   #17
sander17's Avatar
1996 28' Excella
Okemos , Michigan
Images: 42
Stuart2,
That is the complicated part. You also need a float valve in the generator reservoir. Or, tie into the generator's fuel line, bypassing its gas tank. Since it is expecting the pressure from a gravity feed, the inline pressure reducer needs to operate at VERY low pressure. Hmmmmmm............
sander17 is offline   Reply With Quote
Old 03-30-2004, 03:34 PM   #18
2004 19' Bambi
Denver , Colorado
Images: 32
... and again, same site different model.
Link...
Are these cast in Gold or something???
Old 03-30-2004, 03:36 PM   #19
sander17's Avatar
1996 28' Excella
Okemos , Michigan
Images: 42
Colorado_camper,
Of course! It is for use in California. That is one of the costs of living in such an enviro-friendly state.
Old 03-30-2004, 03:41 PM   #20
2004 19' Bambi
Denver , Colorado
Images: 32
Unbelievable! I'll walk before I ever pay that kind of money for a frickin' gas can!
Old 03-30-2004, 03:47 PM   #21
Cracker's Avatar
Pittsfield , Maine
A pair of 2.5 gal tanks for gas only might be my best bet. They would sure be a lot easier to handle when refueling the generator. I was hoping to have room for the 5-gal diesel can - but that looks questionable. If I carry the cans under the toneau cover I plan to install vents on the cover.
Cracker
Cracker is offline   Reply With Quote
Old 03-30-2004, 03:59 PM   #22
Craftsman
Guest
Posts: n/a
$ 699.00 for a gas can? Where are the wheels and engine?
Jack
Old 03-30-2004, 04:03 PM   #23
Craftsman
Guest
Posts: n/a
Cracker, The Nato gas cans are also made in the 2 1/2 gal. size. Same great design. There is also a locking spout that fits these cans that makes pouring a lot eaiser.
jack
Old 03-30-2004, 04:11 PM   #24
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Originally Posted by sander17
Stuart2,
Modern trucks have the fuel pump for the injection system in the gas tank.
300 psi makes the feed to the generator complicated.
300psi? where the heck did that come from. The most presure I have ever seen at a tank pump was 32psi. That's what most Bosch multiports run on stuff like Porsche and VW. My FI suburban only delivers about 10 PSI. A Deisel may pump about 30-40 psi at the lift pump then hit the main pump ON THE ENGINE and get run up to 500PSI on hard lines the last 24 inches. but not at the tank.
Second advantage to having a seperate tank....Unless your truck is diesel, then you got get to the gas station gas.
I'm also anal about checking my MPG. I don't want to throw that off. Keep tabs on MPG lets you know if your starting to have problems.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 03-30-2004, 06:05 PM   #25
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Stuart2,
Unless the truck is direct-injection Diesel, max fuel pressure is 75. Most are usually 35-55.
Old 03-30-2004, 06:23 PM   #26
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
The Duramax diesel can run up to 23,000 PSI at the output of the main pump!
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 03-30-2004, 06:24 PM   #27
Elgin , Texas
Images: 164
Originally Posted by 59toaster
http://www.4x4trailers.com
These guys sell them new in Red (legal thing) and they also have Heavy duty mounts. They also sell a 2.5 gallon version.
I'm liking that 2.5 gallon one. I was wondering about toting gas safely for the generators. Cool beans!
bake315 is offline   Reply With Quote
Old 03-30-2004, 07:16 PM   #28
LEV ZEPPELIN
crazylev's Avatar
2004 19' International CCD
Chicago , Illinois
Greetings.
Personally, I am going to wait for a Ralph Loren or Luis Vitton gas can...they gotta be under a grand, but shlepping these fronm the gas pump to the generater would make my tushie look just marv-o-lus!!!
On a more seriois note...is it possible to syphon or pump out a gallon or two worth of gas from your tow vehicle rather than transport containers of highly explosive petrolium product? Someone must have done this, though it probably is not recommended if you have hic-cups!
Jonathan
Sometimes I wish I were living in the stone age. Then I would know I'm the smartest person in the world.
crazylev is offline   Reply With Quote
gas valves gmlcjb LP Gas, Piping, Tanks & Regulators 5 07-17-2006 10:31 AM
servicing gas part of refrigerator nickcrowhurst Refrigerators 3 02-21-2006 08:46 AM
Gas Furnace ketchumwt Furnaces, Heaters, Fireplaces & Air Conditioning 4 12-04-2003 01:46 PM
Engine will not start - LP Gas detector? AccessMaster Airstream Motorhome Forums 6 08-31-2003 09:38 AM
Oven gas line broken lbrodsky LP Gas, Piping, Tanks & Regulators 4 07-23-2002 04:52 AM
