Not that I can see.
I looked at Jegs and Summit, but see the problem lies here:
The pipe is a small trans line pipe that even if cut, there is no NPT that can go from that size pipe to the 1/2 NPT fitting on the cooler.
The other problem is that Jegs, Earl's and Summit have AN to NTP adapters, however the current connector on the pipe is a male AN and on the cooler it's an NTP female. All the adapters are all male to male that I can find. If there was a female to AN 3/8" to male NTP 1/2" that could seal securely without leaks, that would be just what the doctor ordered, but so far nada.
So, then I took a look at other coolers that are "AN" connectors and they are as small as the stock unit (which on the B-Body is exactly right behind the bumper so that it gets no "real" airflow. I'd really like not to use rubber lines.
Either of you seen a female to male such as I describe or a 8-9" deep cooler that is 11" wide with "AN" connectors?
Thanks for your responses.
Eric
