Go Back   Airstream Forums > Airstream Community Forums > Our Community
Old 09-23-2002, 06:23 AM   #1
Craig
Profile:
Security
What can be done to prevent an AS from being towed, for security purposes. I have my TT parked in my backyard, and was just thinking about how anyone could drive up, hitch up, and pull away.
Craig is offline   Reply With Quote
Old 09-23-2002, 06:54 AM   #2
RoadKingMoe
RoadKingMoe's Avatar
Profile:  2001 34' Limited
Beavercreek , Ohio
As a minimum, put a ball with the shaft cut off up in the coupler (so the trailer can't be towed with a smaller ball) and a padlock on the coupler latch.
You could also sink a large metal loop (rebar for example) deep in concrete in the ground and run a Kryptonite cable through the loop and the tongue A-Frame.
Maurice
AB8XA
WBCCI 5446
The Long, LONG Trailer
Old 09-23-2002, 07:31 AM   #3
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
More ideas
Anything that will take a lot of time, creates noise, or requires tools adds to your security.
Padlocks can be cut off. Better to buy one of the coupler locks that cover the entire coupler (about $35). The key lock itself is completely up inside the coupler where it is virtually impossible to harm. The lock fills the coupler such that a smaller ball cannot be used.
If your trailer has duals, one of the padlockable, expanding chocks that fit between the wheels is useful in several ways.
1. When you are using the trailer, it reduces the motion
2. It chocks the trailer better when up on levelling blocks.
3. If it is set good and tight, it is really difficult to remove.
The expandable chock I have makes it very difficult to get a bolt cutter on the padlock hoop.
If you have a power jack, lower the tongue way down and cut power to the jack. Adds to the time and tools it would take to get the tongue up on a hitch.
A friend padlocks a piece of very heavy chain through the openings in a wheel.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Old 09-23-2002, 08:25 AM   #4
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Craig. Removing the wheels is another way to delay a theft. But if it's in your yard, run city power to it. Now you could install a "car alarm" that has a motion detector.
inlandrv.com
airstreamparts.com
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
Old 09-23-2002, 10:45 AM   #5
RoadKingMoe
Beavercreek , Ohio
Re: More ideas
Strongly agree!
Good idea. Master makes a padlock specifically for the coupler latch that has the loop sheilded, and it's even harder to get to the locking bar on a Diskus lock. An 80lb Hensley hitch head locked into the coupler and cabled through the A-frame and overcenter latches is also a bit of a deterent. <G>
I use chocks on the side on the ground and one of those lockable expanding chocks on the side on leveling blocks. Only way to go on that side.
Better yet, run it through adjacent openings on two wheels... one's going up while the other's going down and they won't rotate very far.
Good ideas!
Maurice
AB8XA
WBCCI 5446
Old 09-24-2002, 08:31 AM   #6
53flyingcloud
53flyingcloud's Avatar
Profile:  Amherst , New Hampshire
brakes
In addition to all of the above 'excellent' suggestions, you might try removing the "break away key", as well. This should lock your brakes on the TT.
Just my 0.02 worth.
53flyingcloud is offline   Reply With Quote
Old 09-24-2002, 08:45 AM   #7
RoadKingMoe
Beavercreek , Ohio
Re: brakes
Just my 0.02 worth.
Wouldn't the electric brakes drain your trailer batteries in a heartbeat?
Maurice
AB8XA
WBCCI 5446
Old 09-24-2002, 10:39 AM   #8
Commercial Vendor
It will also burn up your magnets, in a heart beat, AND, it can also detemper the "spindles," if your coach is plugged into city power.
Result, new axles!!
You can leave the breakaway switch pin pulled for no longer than 5 minutes.
inlandrv.com
airstreamparts.com
Inlandrv.com
Old 09-24-2002, 10:49 AM   #9
53flyingcloud
Live and learn
Whew...
The things you can learn every day~!
I think that's one of the "best aspect" of this forum is that, you can learn from other's past mistakes.
Old 09-24-2002, 01:18 PM   #10
RoadKingMoe
Beavercreek , Ohio
Originally posted by Inland RV Center, In
It will also burn up your magnets, in a heart beat, AND, it can also detemper the "spindles," if your coach is plugged into city power. Result, new axles!! You can leave the breakaway switch pin pulled for no longer than 5 minutes.
Man... sounds like this is something that needs to be secured from destructive pranksters.
Maurice
AB8XA
WBCCI 5446
Old 09-24-2002, 01:29 PM   #11
Commercial Vendor
Maurice. It does happen, all to many times.
inlandrv.com
airstreamparts.com
Inlandrv.com
Some towing Q & A for newbies femuse Towing, Tow Vehicles & Hitches 3 08-24-2004 08:05 AM
Question about towing a trailer murryman Towing, Tow Vehicles & Hitches 3 10-23-2003 08:03 AM
Towing boat trailer? wyhjr Towing, Tow Vehicles & Hitches 9 05-08-2003 10:20 PM
Towing a Small Motorcycle Trailer Behind 25' Safari?? heyskipper Our Community 4 05-07-2003 11:23 AM
towing enclosed racecar trailer fangthorpe Mechanics Corner - Engines, Transmission & More... 1 06-30-2002 04:45 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
