Old 07-01-2003, 10:19 AM   #1
Trailer accident
I dont understand why you cant just apply extra pressure to trailer brakes by manually moving lever. Many years ago i had a horse trailer push me hard on a steep downhill grade i hit the electric brake lever manually and snapped the rig back in line. I also would have thought that all brakes would hit the trailer slightly ahead of tow vehicles. Thank for the info about the different units.
Ajrandzin is offline   Reply With Quote
Old 07-01-2003, 12:42 PM   #2
Ajrandzin
Sounds like a good idea. I'll keep that in mind in similar situations. Thanks.
Harold Becker
Dr. Harold Becker is offline   Reply With Quote
Old 07-01-2003, 01:11 PM   #3
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
Well, you can...
and that's what you SHOULD do. However, in any emergency situation you do what you are trained to do. If you have never given any thought to what to do, or you don't understand what to do, it doesn't happen. Then there is also the panic factor. Some folks panic when things go wrong, then all is lost.
It comes down to experience.
Roger
What is your Brake Controller of Choice? overlander64 Brakes & Brake Controllers 71 11-29-2008 08:40 AM
Some towing Q & A for newbies femuse Towing, Tow Vehicles & Hitches 3 08-24-2004 08:05 AM
trailer wiring Cruiser Electrical - Systems, Generators, Batteries & Solar 4 09-02-2003 01:43 PM
Getting Close! kamadeca Our Community 48 02-05-2003 08:56 AM
Trailer Listing To "Street Side" montanaandy Axles 4 06-07-2002 12:15 PM
