Old 05-19-2019, 07:58 PM   #1
2019 27' Globetrotter
San Diego , California
Tpms
What is recommended to tpms to put on my Goodyear tires for 2019 airstream globetrotter?
glondon is offline   Reply With Quote
Old 05-19-2019, 08:22 PM   #2
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
I’ve used several TPMS systems and the best so far is TST (Truck System Technologies). The one problem is the minuscule screws that hold the cover over the battery can be extremely hard to remove. You can send them back and they say they will get them off, and they don’t seem to charge for that, but they will offer to put in a new battery and O-ring for about ten bucks a sensor. The system tells tire temperature and pressure.
Gene
Old 05-19-2019, 10:19 PM   #3
2018 28' Flying Cloud
Fairfield , California
I have the TST with color monitor and cap sensors. Model TST-507-RV-4-C. Purchased from etrailer. I also changed to metal valve stems. Very happy with product and the worry about the tires it eliminated.
StuartsDad is online now   Reply With Quote
Old 05-20-2019, 03:42 AM   #4
Coaster's Avatar
Saint Augustine , Florida
I used the dill tpms for 5 years before the sensors went south. The dill work well and lasted but I didnít like all the wires. I now have Blu tpms I opted for the internal sensors itís a Bluetooth system. I use an old iPhone 5 with no cellular service as my monitor.
Coaster is offline   Reply With Quote
Old 05-20-2019, 05:09 AM   #5
2019 30' International
Pennsylvania , Pennsylvania
I have the tst 507.....the screw on cap, NOT the flow through.
One word of caution though, there is a tiny o-ring in that screw on cap, and if that comes out when you screw the cap off what happens you ask?
Well, when you screw that cap back on without that o-ring in there, your tire will slowly go flat....just sayin'.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 05-20-2019, 07:16 AM   #6
2018 33' Classic
Ocean View , Delaware
+1 for the TST 507. I removed the "anti theft" covers to reduce weight on the valve stems. Our trailer has "hybrid" stems (part aluminum, part rubber). Have not had any issues with the sensor hitting the rim. I did purchase extra "O" rings for peace of mind.
chickenrx is offline   Reply With Quote
Old 05-20-2019, 08:03 AM   #7
Mollysdad's Avatar
Originally Posted by chickenrx View Post
+1 for the TST 507. I did purchase extra "O" rings for peace of mind.
I recall that TST enclosed a bunch of O-rings in the box.
My requirements were a system that didn't require the use of a screen doing double duty, and I didn't want anything mounted on the windshield. I also hated the monochrome screen from TST because of the (to me) ugly graphic obviously designed to represent a semi-tractor and trailer.
I think the manufacturers should include an overlay of a semi, or truck, or RV or gooseneck trailer...and let you pick.
I picked the TST based on their fine reputation for customer service, and with the color monitor. I installed all metal valve stems myself. (what was I thinking?)
I am totally satisfied. Maybe the best investment in peace of mind.
I have a Ram arm with the monitor at eye level.
Old 05-20-2019, 12:46 PM   #8
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
I have also used the TST system for several years and have been very happy with them. On a previous trailer, a 38ft Mobile Suites, I got a heat warning on one of my trailer tires. Pulled over and found it was delaminating and about to throw the tread. Wire sticking out all around the outside of the tread. Pressure was holding normal so the temp warning really saved our bacon. The TST paid for themselves right then and there.
thewarden is offline   Reply With Quote
Old 05-20-2019, 01:10 PM   #9
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
A vote for Dill internal system here.
Upside internal tire temp monitoring. Downside requires removing tire to install transmitter. Iím on my 2nd system. Sold first with 15ís when I got 16ís.
Iím sold on them.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is online now   Reply With Quote
Old 05-20-2019, 01:13 PM   #10
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
Austin (winter) Lincoln MT (summer) , Texas & Montana
TST 507 works great! I have over 10K miles now on my Goodyear Endurance with rubber/metal valve stems and the TST system. No issues.
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Old 05-21-2019, 12:59 PM   #11
Master of Universe
Gene's Avatar
I sent 3 sensors I could not open—first time I haven't been able to get a stuck screw out of anything—to TST to open them, put in new batteries and O-rings. They called me to tell me they fixed them and are giving me a special screwdriver that fits the very small screws and should work better than the miniature screwdriver set I have. I suggest removing the caps every year just to make sure you can and then clean everything to make sure the screws don't get stuck.
Gene
TPMS - Dill internal mount system wingfoot321 Tires 10 04-19-2016 08:39 AM
Why TPMS is worth it - in my case a DILL TPMS DaKarch Tires 2 08-04-2015 08:37 PM
Valve stems and TPMS cosmotini Wheels, Hubs & Bearings 8 08-06-2013 07:28 PM
Thoughts on TPMS mwells4654 Tires 33 11-02-2010 04:20 PM
Another TPMS... reday Tires 3 07-05-2009 04:53 PM
