I found on a different car forum that the GVWR of a car, specifically on a GM car is on the driver's door. This is the total weight of the car including all possilbe passengers (average weight), gas, etc.
I'll use my car for an example:
1996 Caprice Classic GVWR 5396lbs
The 5396lbs is if the car has 5 passangers, full tank of gas, spare, jack, fluids full plus a very small bit of cargo in the trunk. If the car only has 2 adult passengers, and all the rest, you can take about 500-600 lbs.
I always thought before I got piled on by about 10 guys on the car forum that the GVWR sticker was what the car weighed period without people, cargo, gas.
Eric
